Old 02-24-2017, 06:53 AM
Roy25101 Roy25101 is offline
Default Looking for direction on cutting...
Could I get some advice on how to go about cutting the excess metal off the R-710 Rudder Brace Horn. It won't go through a band saw, it's too thick to snip. Any advice would be appreciated.
Old 02-24-2017, 06:59 AM
Mel's Avatar
Mel Mel is offline
Typically on situations like this, I use a cut-off wheel in a Dremel or die grinder. Wear eye protection and be careful.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 02-24-2017, 07:04 AM
sbal0906's Avatar
sbal0906 sbal0906 is offline
As Mel suggests, I used a Dremel with cut-off wheel but not right up to the line. Then, I finished it with the bench grinder.
Shamit Bal
http://www.flyaroundthesun.com
RV-9A
Working on empennage but the wing kit has been received.
Winnipeg, Manitoba, Canada
Old 02-24-2017, 07:17 AM
Mel's Avatar
Mel Mel is offline
Another caution; try using a belt sander instead of bench grinder. Grinding wheels and aluminum don't play well together.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 02-24-2017, 08:21 AM
edsong's Avatar
edsong edsong is offline
A bench grinder is fine if you use a (3M SCOTCH-BRITE DEBURRING WHEEL) or something similar.
Eddy
Edson Grindeland
Hatton, ND
RV-8 Flying
http://www.hattonflyingcircus.com
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Old 02-24-2017, 08:27 AM
wirejock's Avatar
wirejock wirejock is offline
Default Dremel
+1 on the dremel. Cut it with plenty of extra.
I so have a big electric right angle grinder for cutting get thick stuff.
The Harbor Freight tools work fine.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-24-2017, 08:45 AM
mturnerb mturnerb is offline
Piling on to the dremel bandwagon. I use these wheels:
https://www.amazon.com/Dremel-EZ406-...s=dremel+metal
The ones that come in the dremel kit ("409 cutoff wheels") break easily but these seem quite durable - I've had good luck with them on fiberglass also. SAFETY GLASSES / GOGGLES ARE AN ABSOLUTE MUST when using these wheels.
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 02-24-2017, 11:39 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Ditto, but the House of Balsa 2 inch wheels are easier to use since the body of the Dremel gets less in the way...
Web search for "House of Balsa Tuf-Grind 2"
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-24-2017, 02:16 PM
sbal0906's Avatar
Eddy
Yes, thank you. I forgot to mention that I used the 3M scotch-brite wheel. I've started taking it for granted that that's what we all use.
Shamit Bal
RV-9A
Old 03-01-2017, 06:38 AM
OK... Dremel it is. I'm always looking for an excuse to buy a new tool. Thanks y'all...
