Old 02-23-2017, 09:57 PM
salto salto is offline
Default Molex
After purchasing the wiring harness from Vans and installing it.. Very nicely made.. I have spent far too much time trying to find the 'other' ends for the molex plugs. Vans Web site doesn't seem to have these in in electrical section, Stein who I believe made the harness don't seem to list the plugs they used so I can order the other end which in my view should have come with the harness.
Are there any suggestions please.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 02-24-2017, 06:25 AM
John-G John-G is offline
Salto -
Here in the States there is a company named Mouser and another called Digi-Key that carries a very complete supply of Molex connector products.
Here is a good starting place to find the part numbers for connector style and associated pins you are looking for.
http://www.molex.com/molex/products/...annel=products
Once you know the Molex part numbers you are looking for, you can then purchase through Mouser or Digi-Key. I suggest you first find out the part numbers prior to going to Mouser or Digi-Key otherwise your eyes will glaze over looking through the listings of their stocked items.
http://www.mouser.com/
Also the link for Digi-Key.
http://www.digikey.com/
I usually order through Mouser because the parts typically ship immediately.
Hope this helps you.
Happy building,
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 02-24-2017, 10:22 AM
Tankerpilot75 Tankerpilot75 is offline
Default Email SteinAir
Salto,
You might try emailing SteinAir and asking them if they make the harnesses you bought from Van's. I've found them to be very helpful in the past. I'm sure they can help you if you just ask.
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, Garmin 340, 335, Dual 430s, Stratux hard wired to WS, Dynon D10A (backup EFIS)
Retired - Living the dream - And going broke!
Old 02-24-2017, 11:44 AM
KeithB KeithB is offline
I think I'm missing something. The wiring harness ends in Molex connectors at the baggage wall bulkhead that match the Molex connectors already on the included tail cone wiring. The connectors at the wings match the Molex connectors that are already on the included wing harnesses. The control cable ends end in Molex connectors that match the control stick harnesses that Vans sells. The panel end of the harness ends in bare wires that connect to switches, Dsub pins etc that are entirely dependent on how you are doing the panel. You may still need some Molex connectors (canopy connection, extra wiring like OAT probe but only a couple. Sources above work - Fry's electronics had them on the shelf.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, >270 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
Old 02-24-2017, 12:21 PM
Carl Froehlich's Avatar
As I have posted in the past, the RV-14 wiring kit is, in my opinion, more aggregation than value. Just trying to do pin to pin on the prints is a headache. Another example is the bulkhead molex commenctors on the aft side of the baggage compartment. These not be there at all so don't use them. Just run the wire to the tailcone.
Get your own male and female Molex and D connectors and wire it like any other kit. Whatever you do first cut off the tiny plugs that connect to the roll and pitch trim servos. These plugs are amazingly fragile. I chased my tail for three days to figure out why the elevator trim would not calibrate with the EFIS. This tiny connector had an intermittent. It and the wing servos got real Molex connectors - problem solved.
Old 02-24-2017, 03:07 PM
mturnerb mturnerb is offline
I'm using this method for those connections in the tail: https://www.youtube.com/watch?v=f8DCvBV2V4M
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 02-24-2017, 03:08 PM
Thanks everyone for the input. I guess the two areas that I'm finding difficult to track down the 'mate' for the other end of the wiring harness are the position lights on the wing tip and the control column. I would like to utilise the receptacles for the plugs that are part of kit and because these are a specific size locating the right mate for the harness plugs is quite a challenge. Of course I could change the plugs out and ignore the receptacle. Part numbers for the various plugs on harness would be helpful.
Thanks Guys. 👍
Kit 140241
Tail Feathers done
Canopy next. Phew!
Old 02-24-2017, 03:26 PM
Nova RV Nova RV is offline
The control stick connectors are Molex Mini-Fit part numbers 43020-1200 (female) and 43025-1200 (male). The connectors do not include pins so you will need the corresponding mini-fit pins to go with them.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 02-24-2017, 03:56 PM
These plugs will not work if you want to use an Infinity grip (not enough pins). A D connector is fine for this application.
Old 03-02-2017, 07:19 AM
jswareiv jswareiv is offline
Default Molex
Salto,
A friend of mine had these part numbers on his blog and he says it's what you are looking for:
http://rv-14a.blogspot.com/2016/07/a...n-harness.html
http://rv-14a.blogspot.com/2016/08/w...harnesses.html
Hope that helps.
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW
http://rvbuild214sw.com/
Dues paid to 2018.
