Old 02-23-2017, 06:58 AM
asw20c asw20c is offline
Default Tie-Down Ring
Is the tie-down ring (tri-gear) that screws into the tie-down bracket on bulkhead F-01412 supposed to be included in the empennage kit? As far as I can tell it makes its first appearance in the plans on page 10-25 in figure 1. My kit did not include the ring.
Empennage Complete Except for Tips
Wings Underway
Old 02-23-2017, 07:03 AM
n982sx n982sx is offline
No, you have to order it.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 02-23-2017, 07:52 AM
mturnerb mturnerb is offline
These are great as alternatives to standard Van's tie down rings (I had a set on RV-12):
http://www.cleavelandtool.com/Stainl.../#.WK73AhIrK9Q
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 02-23-2017, 10:09 AM
flightlogic's Avatar
flightlogic flightlogic is offline
Red face at least ten knots
The Cleveland seem expensive at first. Have had mine over a year now... and I swear the plane is much faster.
"Kindness is never a bad plan."
Work bio: Avionics tech support; ATP rated in planes.Helicopter rated, balloon instructor, seaplanes and for grins, Phantom Drone pilot. Instructor for air medical and law enforcement tactical radio systems. Fly my RV9A to work every week. Janitor when and as needed.
Old 02-23-2017, 10:11 AM
ppilotmike's Avatar
Default Do you guys..
..typically leave them in the plane, even when flying? I thought the idea was to carry them and install them once you've landed, not leave them in at all times... No?
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/15/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
Old 02-23-2017, 10:14 AM
rleffler's Avatar
rleffler rleffler is offline
In the plane, yes.
Installed on the plane, no.
btw, I have the Cleaveland rings. I only use them a small percentage of my trips, so I don't leave them in.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 02-23-2017, 10:22 AM
bhester's Avatar
bhester bhester is offline
Default Installed?
I leave the one on my tail installed, I have a nut installed on it and it is tighten down to the mount. I have nutplates installed on the side walls in the baggage area that the wing tie down ring are installed into when not in use.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2017 VAF donator - alot better than any magazine subscription
Old 02-23-2017, 12:59 PM
The aft (tail) tie down ring is also intended to be the tail strike protection. If you use something different, it would be a good idea to push the tail down and confirm the rudder cant come in contact with the ground (also consider it digging into soft ground on a non paved runway).
Flying with none installed in the rear... not recommended.
Scott McDaniels
Hubbard, Oregon
Old 02-23-2017, 06:14 PM
schaplerrh schaplerrh is offline
The standard tie down rings that came with my RV7 (purchased from the builder already flying) are rusty. I'd like replace what I have but can't justify $25 a piece Cleveland tie down rings. Is VANs the only source for new rings, or are the standard rings just Home Depot stock?
Robert
Old 02-23-2017, 06:29 PM
rleffler's Avatar
Robert
These are $6.95 ea.
http://www.cleavelandtool.com/Forged.../#.WK-MA5E8KhA
Bob Leffler
