Old 02-22-2017, 04:26 PM
Jamesey Jamesey is offline
Default Brake caliper guide pins
Not mentioned in the destructions as far as I can see, anyone put lube on the brake calliper guide pins, and if so, what did you use??
Old 02-22-2017, 04:35 PM
tomkk's Avatar
tomkk tomkk is offline
I use the same silicone base brake lub that I use on my car. Autozone, etc. carries it.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
Old 02-22-2017, 05:27 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Me too
Brake Caliper Lube from auto parts store
I put it on the guide pins and between the puke and pad plate.
Works good.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2017 VAF donator - alot better than any magazine subscription
Old 02-22-2017, 06:58 PM
AirHound AirHound is offline
Works good.
What does it do? Prevent anything?
Doug
Old 02-22-2017, 07:24 PM
bhester's Avatar
Default Lube
I think it helps to lube the pins so they slide smoothly and between the pad plate and puck, it is sticky and seems to help the parts keep from vibrating. At least that is my thoughts and it has worked well for me, so I keep doing it. Others may say it's not needed. To each their own. My brakes work great and don't make noise.
Old 02-22-2017, 10:08 PM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default Brake Caliper Pins
For the record, in 14 years I have never used lube when changing brake liners and have never had an issue with the caliper alignment. Probably doesn't hurt as long as you don't get it near the liners.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,800 HRS
Ft Worth, TX (T67)
Old 02-22-2017, 11:29 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I'm pretty sure a thin film will help reduce/prevent corrosion.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-23-2017, 04:31 AM
madmaveric's Avatar
madmaveric madmaveric is offline
I've not done mine yet (still in the packaging) but I had assumed there would be dust seals on the pins.
If there are no dust seals then the downside will be dust/grit sticking to the lube and causing extra wear (especially when using grass runways).
Here in the uk it is probably still preferable to leaving them open to the moisture as I think the extra wear would probably be less problem than the corrosion.
I'll have to check with my inspector to see if my thinking is correct.
RV12 empennage, wings and fuse finished, finish kit now under construction.
Blog
Old 02-23-2017, 04:45 AM
wilddog wilddog is offline
I use the dry graphite rattle can spray on them. It drys and doesn't pick up dirt.
Old 02-23-2017, 06:46 AM
Fast Eddie B Fast Eddie B is offline
A slightly different setup, my Sky Arrow has Marc Ignegno brakes where the caliper is fixed and the rotor floats on pins.
I had one brake dragging, and it was due to corrosion on the pins causing them to bind:
This can also lead to uneven brake wear.
It's now my habit to very lightly apply disc brake lube on the pins with a q-tip, more or less monthly.
In short, I think a tiny bit of lube on any brake part that's designed to slide is a good idea.
