Old 02-21-2017, 05:52 AM
JDA_BTR JDA_BTR is offline
Default Flap positions
I'm attaching my flap motor and the sensor for flap position behind it. Can someone send a pic of the flap actuator at the max extended position? My sense of it is if I put the sensor at the lowest position in the screw slots it will be right when calibrated later..... It is harder to get a screwdriver on it later though when the actuator is bolted in all the way.
And thank goodness I put the sensor in now instead of later. I'd hate to have to pull those flap tubes out again....
N1463 seems a good number....
Old 02-21-2017, 01:01 PM
czechsix's Avatar
czechsix czechsix is offline
Is the flap position sensor part of the kit from Vans? If not, what are you using?
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 02-21-2017, 08:04 PM
I bought vans kit. The little slots in the aft side of the flap motor bracket accept the little ray Allen sensor perfectly.
Old 02-21-2017, 10:38 PM
KHeidorn KHeidorn is offline
Default Flap Video
I made my own flap position mount.
Here is a video of it in operation.
https://youtu.be/z-5nJPAEixc
Ken Heidorn,
Debur..Dimple..Rivet..Repeat...
"You're never too old to learn something stupid." - unknown
