Old 02-20-2017, 10:26 AM
D&M Dan D&M Dan is offline
Default Fire Extinguisher Position
Wondering where others have mounted their fire extinguisher in the 12?
N930DD (Registered)
Home Field KSDC
Paid 2016
Old 02-20-2017, 12:02 PM
DHeal DHeal is offline
Laterally in the big U-channel between and behind the seats. Easy to reach, yet out of the way. Alternatively, you could mount it on the console between the occupants' footwells, but I have Van's optional map holder located there. I also like keeping this console area free of anything that would interfere with my stretching my right leg out on long cross-countries!
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 600+ hours (as of Feb 2018)!
VAF donation through June 2018.
Old 02-20-2017, 10:54 PM
I put an adhesive Velcro band around my small halon extinguisher and just stick it to the carpet aft of the center console.
Old 02-21-2017, 08:11 AM
bruceflys bruceflys is offline
Default Extinguisher Hard Mounted
On the floor upslope ahead of the fuel valve, next to the canopy breaker (hopefully you have a canopy breaker too). The velcro strap to carpet is clever, but I wonder if the extinguisher becomes a missile in a crash. Ours is bracket mounted.
Bruce
RV-10 - 95% complete project For Sale
RV-12 - built for wife now flying light sport
SeaRey flying 2012 - Sold 2017
2017 Contribution made
Old 02-21-2017, 10:37 AM
I try to securely locate (sorry, no Velcro) my emergency supplies within easy reach of a pilot/passenger suspended upside-down and confused in an inverted airframe. My emergency egress kit contains my Halon-type fire extinguisher in a quick-release mount, a multi-task knife, work gloves, and a pair of broad-nosed pliers (IMHO, pliers and gloves may prove more useful than a breaker bar in removing portions of a shattered plastic canopy). The latter two items will hopefully prove useful in removing sufficient portions of the canopy to egress in style -- at least that is my thinking.
ps -- A shovel would be nice as well, but perhaps a bit too much. Better to spend your time and money on pilot proficiency and aircraft maintenance.
Old 02-21-2017, 05:58 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Default Fire ext
Mounted on the floor, the upslope of the tunnel.
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2018 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 02-22-2017, 07:37 AM
Default Canopy Breaking
See this video for canopy breaking with a small speciality hammer:https://www.youtube.com/watch?v=fRvQxGl4kt4 The hammer has a pointed end used to crack the acrylic plastic. Blunt nosed pliers may not have that effect.
Bruce
Old 02-22-2017, 07:51 AM
rgmwa rgmwa is offline
I have one of those little hammers too, but I think the fire extinguisher might be a better canopy breaker.
rgmwa
120346
Old 02-22-2017, 10:04 AM
I figure that in a turnover the canopy will likely already be broken and a breaker-tool will not be as useful as pliers/gloves in clearing away already broken shards of plexiglas. The breaker-tool might have little effect on the broken large flexible pieces of plexiglas. To each his/her own -- hopefully we won't have to use these tools!
Old 02-22-2017, 10:41 AM
N941WR's Avatar
N941WR N941WR is offline
You also have to assume there will be limited room to swing such a hammer, maybe 12" at the most. I doubt you can get enough momentum up in that short distance to break anything with one of those hammers.
However, I would love to be proven wrong.
As to the OP's question, I mounted my fire extinguisher in front of the spar, on the passenger's side. It is out of the way and easy to reach. I have no idea if this location will work with a -12 or not.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
