Old 02-18-2017, 10:27 PM
Snoho3 Snoho3 is offline
Default Hinge pins - Tip Up -9A
Working on the quick release for my tip up canopy. The plans call out an AN438-16 bolt for the hinge pin, which is threaded I believe. But the drawings show an unthreaded bolt. Am I supposed to grind off the threads? If so should I shorten the bolt? How much? I didn't see any reference to this in the plans.
I know that there are several ways to accomplish a quick release function. I would only be planning to use mine during the build (if/as needed) or I suppose for occasional maintenance. It really seems to me that pip pins would be a much simpler solution. I am thinking about adding access panels on the forward skins, so getting to the pip pins would be a simple matter.
What are other -9 tip up builders doing in this area? Appreciate any input - thanks.
Snoho3
RV-9A - Tail, wings complete
QB Fuse complete
Finish Kit in work
2017 dues gladly paid
Old 02-18-2017, 11:27 PM
Flying Canuck Flying Canuck is offline
I remember being puzzled about this as well. Then I found it on the plans. Top right corner of drawing 47 shows what to do with that bolt. I believe that's a AN43B-1, funny looking bolt with an eye on the head.
Claude Pitre
Building RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S mounted. Final push to the finish line, I hope.
Old 02-18-2017, 11:53 PM
wjb's Avatar
wjb wjb is offline
I recommend building the release mechanism to Van's print; no pip pins. It will end up being a tight fit (with all the other structure pushing on the 771 skin and other parts of the canopy, and the extra leverage from the release handle will help getting them inserted. I'd be surprised if you could insert pip pins at all without a guide pin to get everything aligned.
My use case is the same as yours, and I cut down the release handle to seat against the sub panel when the pins are fully engaged.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Avionics and FF underway!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 02-19-2017, 09:00 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Pins
The plan calls to cut them and round them over.
I initially did this and then replaced them. Second time I ground them
To a point, the point works better for self centering the hole in the nylon
inserts of the canopy frame. I also cut the handel down so that it is mounted
On the sub panel. I have a gizmo dock with a Garmin gps on the panel pressure
Fit. This can be removed to get to the handel on the sub-panel.
Al Girard, Newport, RI
N339AG
RV-9
Old 02-19-2017, 10:49 AM
Thanks very much - I missed the call out on the plans. It was the end of a long day in the shop... Searching on this forum I see some pics of the quick release handle oriented vertically (downward). The pins retract with a twist instead of a pull. This makes a lot of sense to me as I will have no need to access this handle in flight. And I'd like to keep the area behind the panel as clear as possible. Anyone using this config and if so are you satisfied?
Snoho3
QB Fuse complete
Finish Kit in work
Old 02-19-2017, 11:23 AM
bruceh's Avatar
bruceh bruceh is offline
I shortened the canopy release handle to keep it back on the subpanel. Lots of photos in my build log.
Bruce Hill
RV-9A N5771H flown over 500 hours!
2017 VAF donator
EAA Tech Counselor
Old 02-19-2017, 11:48 AM
Thanks Bruce, I saw that on another thread. To deploy the handle you will still need to pull it aft a few inches from the sub panel. My panel isn't laid out yet but I am sure there will at least be many wire runs there, if not actual boxes. Isn't that still a very congested area? Definitely not trying to be a pain here or to second guess what is working for you, but just wondering if there is downside to a twist type of handle oriented vertically. I appreciate your input, and anyone else who cares to comment.
Snoho3
QB Fuse complete
Finish Kit in work
Old 02-19-2017, 12:01 PM
Snowflake's Avatar
A few people have used a torque tube to transfer the rotation from behind the panel to below the panel. I have seen photos here on VAF of two installations, one with the original T-handle sticking out under the panel, and one with a large knob attached to the end of the torque tube (pointing straight down at the floor).
Personally, I think these have the advantages of both relocating the handle, *and* maintaining accessibility in an emergency. My -6 tip-up didn't have the handle at all when I bought it, the lever holding the pins in position was just bolted in place behind all the panels for a "semi-permanent" installation. I bought a new T-handle from Van's, drilled the hole in the panel, and mounted it as per the plans. When I had to remove the canopy to repair a cracked frame, it was trivial to pull and release.
Thankfully I have not needed it for any emergency situation. But I am happy to have it as an option if it ever comes up.
Rob Prior
Old 02-19-2017, 12:31 PM
Sam Buchanan's Avatar
hall monitor
Release mechanism installed as you described in 1998, used it once for access, see no reason to not recommend it for current builders.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 02-20-2017, 02:53 PM
N130WN's Avatar
N130WN N130WN is offline
I built the mechanism per the plans, then modified a couple times for forgotten reasons, and finally replaced the whole works with a bolt, washer and nylock. No regrets so far. (I have access panels in the front outboard corners). Just another option to consider....
Larry Bowen
RV-8 Built, sold, missed.
RV-7 Built, sold, missed.
RV-8 Empannage ordered ...
