Old 02-15-2017, 07:03 AM
Default Moony prompted
Don't know about the 10 at the top of the VS. On the 8 we put a RAMI under the fiberglass cap on top of the VS and faced the elements forward, like on an old Moony. Works very good, is up out of the way and looks cool up there. We really don't see that much drag from it and with the NAV/COM, Antenna, and marker beacon being TSO'ed we have the back up of a VOR/ILS that meats the standard if needed. Just what we did, Yours, R.E.A. III #80888
Old 02-15-2017, 08:20 AM
bhester's Avatar
bhester bhester is offline
Originally Posted by T.O.Craig View Post
Seems like everybody likes them and they are priced well.
Same with the Archer wingtip Nav Anteena
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2017 VAF donator - alot better than any magazine subscription
Old 02-15-2017, 08:53 AM
Super Moderator
I've always used the cat whiskers underneath the tail cone. Am able to pick up VOR's 90 miles away, and there is great signal strength on ILS for either left or right intercepts.
And once last year in the middle of nowhere I was able to pick up my IFR clearance on the VOR frequency with FSS while airborne. Was nice and clear and glad I used the cat whiskers.
I'm sure it's slowed me down 10 knots, though. No wait, that's the 3-bladed prop.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 02-15-2017, 11:18 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
In my personal experience, the Archer wingtip antenna seems to work just fine as a VOR antenna and for the most part a Localizer antenna. The issue I experienced was in certain situations when turning on to the localizer, the GS would drop out due to blockage from the wing, which in essence creates a directional antenna. I have one in each wing tip, and both would exhibit this issue. While this antenna seems to be matched well for the vor and localizer frequencies, roughly 110 MHz, the glide slope pairing frequencies are not so well matched. The glide slope frequencies are in the 332 MHz range. I installed a cat wisker on the belly in the rear. It works just fine sharing it as the localizer/glide slope antenna.
I still use one of the Archer antennas with my number two radio.
When installing the archer antenna one has to religiously follow the installation instructions with regard to wire routing and placement. If you want to get good performance.
Bill Peyton
RV-10 - 780 Hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 02-15-2017, 04:31 PM
Originally Posted by Bill.Peyton View Post
In my personal experience, the Archer wingtip antenna seems to work just fine as a VOR antenna and for the most part a Localizer antenna. The issue I experienced was in certain situations when turning on to the localizer, the GS would drop out due to blockage from the wing, which in essence creates a directional antenna. .
Might not be "wing blockage". A 3/2 wavelength dipole (which is what the Archer is at GS frequencies, although it is not a simple, straight dipole) has a very strong null (not zero, but many dB down) at about 20 degrees off the nose. I have no idea what the pattern for a real bent, folded Archer looks like.
Old 02-15-2017, 07:30 PM
DRMA DRMA is offline
I have mounted cat whiskers at the top of my vertical stabilizer, under the rudder counter weight overhang, with them facing aft. Wasn't had to do and keeps the antenna elements up out of the way. If you would like a few pictures, send me your email address by private message and I'll send you some.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2018 VAF Dues Paid
Old 02-16-2017, 07:04 AM
T.O.Craig T.O.Craig is offline
Default Rami selected
Thanks for the good info. I have elected to use the Rami AV 525....
Craig Rufi
RV-10/Empennage/Wings/QB Fuselage/Wiring/Doors done finally, Cowling done. Stein panel complete, and connecting all those wires :-))Thousand Oaks, Ca. Dues paid for 2017
Old 02-16-2017, 07:36 AM
ScottSchmidt's Avatar
ScottSchmidt ScottSchmidt is offline
Super Moderator
Default +1 for cat whiskers on top of VS
I have Bob Archer and it does not have the range of a cat whisker. If I were building again, I would put the cat whisker on top of the VS. Strasnuts on this forum has that on his RV-10 and it looks great and is completely out of the way from people (at Oshkosh) breaking off your antenna.
Just cut two slots in the top of the VS and it fits perfect up there.
Scott Schmidt
Salt Lake City, UT
RV-10 N104XP (1150 Hours)
RV-12 N321UT (Sold)
Old 02-23-2017, 06:17 PM
Strasnuts Strasnuts is offline
Default Whiskers
As Scott said above, I have the cat whiskers on vertical. I also have the bob archer in the wingtip. The whiskers work almost double the distance of the bob archer when I compared them on the same VOR frequency.
A&P RV-10 Flying 850 hours
SuperSTOL Flying 100 hours
Old 02-24-2017, 04:50 PM
nbachert nbachert is offline
I've researched a little but what is the preferred model and where is a good place to purchase the cat whiskers? Thanks
Nick
