Old 02-14-2017, 09:35 AM
Bernie Knight Bernie Knight is offline
Question RV8 front seat -back and base
Hi all,
After purchasing an RV8 with a custom race car type carbon fibre seat I am finding I am sitting quite high and forward.
The seat attaches to the rear frame support for the stock metal seat back. It's then mounted on a custom seat bracket at the front holding it up about 3".
I am considering removing this race seat and placing the back seat panel back in and cushion.
I will need to make/ fabricate a new seat back panel. I have found photos of this panel.
I've searched the Forum for photos of the standard seat back and seat base.
Is there a seat base or do the base cushions just sit on the floor? How is the seat back attached to the support frame and floor area. Riveted, screws etc ?
Sorry about all the questions, but I don't want to re invent the wheel.
Any photos of this particular seat back attachment, cushions etc would be appreciated.
If its easier to just email photos..
kni-time@bigpond.net.au
Thanks.
RV8a
Old 02-14-2017, 10:35 AM
tfriendshuh tfriendshuh is offline
the seat back attaches via a piano hinge riveted to the floor panel. The cushions sit on the floor - a wedge shaped one at the bottom and the flat one for your butt on top of that. The back cushion fits against the seat back with velcro.
I have some pics around here somewhere that I'll post up if someone else doesn't beat me to it...
tim
RV-8A N6677F IO360 CS
Dues paid through 2018
Old 02-14-2017, 10:40 AM
tim
Old 02-14-2017, 11:17 AM
skylor's Avatar
skylor skylor is offline
Default Fron seat bottom cushion
In the stock configuration, the base cushions only partially sit on the floor. There is also a metal "ramp" that extends from the floor to over the top of the spar center section. You will need to purchase and install these parts as well.
Skylor
Old 02-14-2017, 11:53 AM
Skylor
exactly correct - I don't have pics of it at hand unfortunatly
tim
Old 02-15-2017, 12:01 AM
Tim, Skylor
Thanks for the replies and Tim for the photo. I'm sure my metal fabricator can make the back panel etc.
The base ramp makes sense also - hence the wedge cushion to level and the top cushion.
Once I get the race seat completely out, I'm sure it will be clear as I'm currently upside down looking under
I like the race seat idea, but I'm just slightly too big from the seat sides.
Thanks again guys.
Bernie.
RV8a
Old 02-19-2017, 12:08 AM
Cool
Thanks Tim
Appreciate you sending the photos.
Just love this Forum ..
RV8a
Old 02-20-2017, 02:48 AM
SHF SHF is offline
Some pics of the fwd seat ramp
http://i63.tinypic.com/96yo3n.jpg
http://i64.tinypic.com/15dw869.jpg
http://i63.tinypic.com/15i5g8n.jpg
http://i68.tinypic.com/wvnx36.jpg
Old 02-21-2017, 01:32 AM
SHF
Thanks for Posting the photos...
The race seat is mounted on front brackets 2" approximately up.
The rear on a timber cross member that is secured with right angle brackets.
I'm leaning to removing and replacing with a fabricated back panel for the seat back.
RV8a
