Go Back   VAF Forums > Model Specific > RV-4
Old 02-12-2017, 04:31 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Exhaust -- four into four?
Has anyone done the 4 into 4 exhaust on a -4? and, if so, any issues on the install?
Ron
RV-10 Co-built (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV)
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385
Very Happy Contributor
Based at KCLW (Clearwater, FL)
Old 02-12-2017, 08:47 PM
ESPRV4 ESPRV4 is offline
Default Dave Taylor
Hi Ron
My -4 has the Vetterman 4 pipe exhaust. Larry convinced me to go that way and I'm glad I took his advice.! Very easy to install, and efficient as well as sounds GREAT ! The only issue I came across was under the tight -4 cowl it was difficult to fit a carb heat muff. If your injected then no probs.
Cheers
VH-HOC
0320 wood prop
60+hrs
Donation due this year.
ESPRV4
Old 02-13-2017, 04:25 AM
Default Do it !
I have the 4/4 Vetterman on my -4, and its a great system..a unique sound like no other. I have a home-built heat muff and carb heat muff..no issues at all. On another note..we visit Largo Fl. a couple times a year, but havent flown the -4 down yet. Send me a PM if youd like some detail pics of my 4/4 set-up. There are some on VAF from way back, but Im not sure where.
Bill E.
RV-4/N76WE
41 Aeronca 65TC Defender
8A7 / Advance NC
Old 02-13-2017, 04:52 AM
RONSIM's Avatar
Default Thanks for the replies
I feel better about the "challenge" -- helping a fellow RV'r whose original system, 4 into 1, (many years old!) went south on him.
Lots of RV'rs at KCLW -- come on down and warm up!
Ron
Old 02-13-2017, 02:52 PM
smokyray's Avatar
smokyray smokyray is offline
Default Way back when...
Ron
Ron, I bought one of Larry's first 4 pipe systems for my RV4 when his business and the RV world was relatively new.
My performance was always excellent but more importantly that same system has 2500 hours, 25 years of use and NO cracks whatsoever...something to be said for quality....If the 4 into 4 is half as good you should love it...
V/R
Smokey
PS: what type system are you referring to? Vetterman or something else?
Old 02-13-2017, 08:17 PM
Michael Henning Michael Henning is offline
I have the 4/4 Vetterman system, 200hp injected, sounds outstanding and no problems at all. If you are doing a smoke system, get two injectors.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 02-14-2017, 07:09 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default What does 4/4 mean ?
I just ordered a new 0360 system for RV4 from Clint. Larry V was very convincing that 4 pipes with 20 degree down turns was optimum. I had asked Clint if a 2 into one collector was available for my 0320 / -3 and he said combining pipes would reduce HP 15%. Larry also shared his experience regarding noise. He said a straight pipe pressure pulses interact with the fuse bottom and cause "drumming" due to pulse waves attaching to the fuse. Thus 20% down is preferred.
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
Old 02-14-2017, 07:51 PM
Mine are turned down, no pulsing. He makes a great exhaust.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 03-05-2017, 09:15 PM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
I also have the 4 pipe system. I always get compliments on how my airplane sounds. There is a whole lot of exhaust under my cowl. Very tight fit, but heater works great. Carb heat works great. Sound is great. Sound in cruise... perfect.
You won't be sorry.
RV-4 (not the builder)
0-320 (160HP) Sensenich Metal Prop
N617TN
Old 03-06-2017, 06:57 AM
grubbat's Avatar
grubbat grubbat is offline
Default 20deg down
I was getting the drumming from the power pulses and the 20deg did the trick. Vetterman is the way to go!
Craig
RV-3 Sold
RV-6a Sold
RV-9 IO-360 CS, Flying
1967 Twin Comanche C/R, Flying......
