Old 02-12-2017, 03:56 PM
olderthandirt olderthandirt is offline
Default Another VR failure
Sorry I know this has been beaten to death, but today my Ducati VR is probably on last leg..I have 26.4 total hours on plane and VR is under panel....today it was showing at idle -.1 and -.2 and in air +2 and battery discharged to 12.6 after hour of flight..it started out 13.7 because I have a battery maintainer on it...if everyone agrees it is going out I have a JD VR which I can install with a modified plate...just asking
Retired Firefighter/Para-Medic
Sold 182 Skyelane
sold Super Cub
Building RV 12 E-LSA
Paid thru 2016, even though exempt
RV 12 completed, waiting DAR
Old 02-12-2017, 04:42 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
If it turns out bad....make sure you send into Van's a failure report. 26.4 hours is ridiculous. From a class I attended last weekend; it seems only to be "epidemic" in RV-12s.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 02-12-2017, 04:52 PM
bajapilot bajapilot is offline
I have to agree Ric, I have over 1100 hrs on my Rans S-7S with original regulator. I have about 170 hrs on my RV-12 and mine is going TU. Only getting anywhere btw 12.8 and 13.7 volts the last few flight.
I'm very involved with the Rans community and with many hundreds flying I don't hear of many VR failures. Something about the RV-12.....
Bill
Old 02-13-2017, 05:02 AM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
Not sure what battery the RV-12 uses but Odyssey says in their manual the battery is good if it shows 12.65v or better open circuit (no load).
Alan Carroll
RV-8 N12AC
Old 02-13-2017, 12:42 PM
Phantom30's Avatar
Default Voltage Regulator Issues
I do believe it is time to get to the bottom of our RV-12 voltage regulator problem. I've read all sort of reasons...heat, vibration and installation errors being the cause.
Scott just recently stated installation error being the most likely cause of our problem. I really have a rough time swallowing this.... Not fully inserting pins or plug. Just maybe the plug being supplied doesn't allow for complete seating on the voltage regulator.
Why is this a RV-12 issue? Other Rotax (other a/c) don't seem to be experiencing the level of failures.
Just saying, maybe it is time for some "factory" help; as failures have occurred with the regulator moved away from heat. AND Scott is probably onto the cause...being electrical connections (just don't believe it is installation error)!!!
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
Old 02-13-2017, 12:58 PM
What I actually said was "A lot of failures have occurred as a result of installation error (plugs not fully seated in the regulator, or wires not fully seated and locked into the plug)."
I didn't say it was the primary cause (I have no way of knowing what the actual percentage of the total failures is).
A lot of failures have occurred with melted connectors and/or input pins in instances where the pins weren't fully seated.
My primary point being that there is not one single cause for the failures, and that at least some are like installer induced.
Scott McDaniels
Hubbard, Oregon
Old 02-13-2017, 01:22 PM
Phantom30's Avatar
Scott, I'm not climbing onto you or Van's(couldn't be happier with the support given)....just saying, there has to be more to this then "faulty installation errors". My reading into this points to poor pin/lug engagement....as the "heat problem" has been addressed.
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
Old 02-13-2017, 01:31 PM
Plummit's Avatar
Plummit Plummit is offline
I would think that given the above, there may be a problem with the plugs or the instructions to assemble the wiring/plugs to the VR. More than two similar failures indicate to me that something needs to be improved. That's my take anyway.
-Marc
N814RV
2018 Donation made!
Old 02-13-2017, 01:39 PM
I think that what you're reading is that a lead-acid battery is at full charge at 12.65 volts.
But if the engine is running and you see only 12.65 volts, that means the alternator isn't charging the battery, since it takes at least 1.5V above battery voltage to push a charge into the battery.
Charlie
Old 02-13-2017, 01:46 PM
Phantom30's Avatar
Charlie
For the optimum charging of our batteries voltage should be 14.3...I think our regulator puts out around 14.1 volts.(which is fine) when everything is running right.
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
