Old 02-03-2017, 07:03 AM
KitfoxJoe KitfoxJoe is offline
Default Question- how did you run and support your egt/cht wires
Hello to all
I am getting to the stage where I am installing the EGT /CHT probes. And would like to know how others have Run and supported there egt CHT Probe wires. Thanks Joe http://i1369.photobucket.com/albums/...ps29jcwre2.jpg
Old 02-03-2017, 07:24 AM
Auburntsts's Avatar
I used Adel clamps hung from various points along the engine/baffles using valve cover screws, baffle attach screws, and case bolts. I ran my EGT wires using the valve cover and baffle attach points along with my bottom plug ignition wires. My CHT wires were run using case bolts as attach points and they shared clamps with my Alternator and starter wires on either side of the engine. YMMV....
I see you are in Woodbridge. I live in Montclair. I'm more than willing to pop the cowl on my 10 if you'd like to see how I wired things up first hand. Just let me know and we'll setup a time to meet at my hangar in Manassas.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 02-03-2017, 08:59 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default wires
I took a different approach.
After dealing with wire routing for years, last year I had engine off and updating FWF items like adding a second heat muff inlet for cold winter days.
I added FW penetrations (2)that aligned with the space under the cylinders and above the intake tubes. On the cockpit side, I split the CHT/EGT wiring for left and right and routed them accordingly. FWF side I routed the wires through a flexible sleeve like is used to protect the lead/probe connection. obviously straight shot to cht locations and hooked around tubes to hit egts.
Keeps wiring "inside". Very little need for support. but did tie midspan to something else when complete. I am very happy with less clutter of wires FWF.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 02-03-2017, 09:41 AM
snopercod's Avatar
Default photo of my installation
Basically, my EGT probes are supporting the wires. Toward the firewall, I used Adel clamps to hold the wire bundle. Where the wires passed next to the exhaust pipes, I loosely wrapped them with a piece of Thermo-Tec. The red RTV is just to keep the Thermo-Tec from sliding around. (This was my brand new Custom Aircraft crossover exhaust.)
(2018 dues paid)
Old 02-03-2017, 10:02 AM
The Van's web site has some good photo references of the RV-14 and 14A prototypes.
These airplanes are done pretty much the same as all of the company prototypes were. It is a proven durable installation that maximizes accessibility of the engine compartment for maint. / repair, etc. (something that people often overlook)
https://www.vansaircraft.com/public/rv14Cockpit.htm
Scott McDaniels
Hubbard, Oregon
Old 03-19-2017, 03:22 AM
rv8ch rv8ch is offline
Default very useful photos
The Van's web site has some good photo references of the RV-14 and 14A prototypes...https://www.vansaircraft.com/public/rv14Cockpit.htm
Thanks Scott - whoever decided to put these pictures up deserves a medal - they are really helpful.
Mickey Coggins
http://rv8.ch
Old 03-19-2017, 07:16 AM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is offline
Default Adel around intake tubes
I used an adel around an intake tube, and some ell shaped bracket I found in my junk pile:
Alex Peterson
RV6A N66AP 1600+ hours
Maple Grove, MN
Old 03-19-2017, 12:32 PM
carlrai's Avatar
carlrai carlrai is offline
Default Another iteration
Carl Raichle
Lutz, FL
RV-9A N194CR
Based at KZPH
AA4SR
Old 03-19-2017, 01:38 PM
Default tubing
Carl, is that some kind of tubing around your CHT probe wire?
Mickey Coggins
http://rv8.ch
Old 03-19-2017, 03:21 PM
RV6_flyer's Avatar
Thanks for posting that. I love the 360-view images. Wish they had that 25-years ago when I was building my RV-6. Was very lucky to have a Pawnee getting a new engine several hangars away to look at for planning my -6 setup.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
