Old 04-26-2016, 09:18 AM
TimO TimO is offline
Default RV-14A Vetterman Exhaust
I'm getting a bit behind with my online time these days. When pushing thru to the end of the build, I try to stay focused and get too sidetracked. But for a while now I've had the RV14A version of the Vetterman exhaust installed, and recently I finished the cabin heat system, so it's time to post some pictures!
I should warn you, there are many many things in the photos that aren't complete. You'll see many loose nuts, and no hoses have been tightend yet. At the time of the photos the engine monitor was in process of being installed, but today that is all complete. So look at the photos for what they are...just pictures of the exhaust system. I'll post more complete pictures on my website in a few days, as I'm just about wrapped up with everything FWF, and am about to close off the cover forward of the panel and prep the plane for paint.
For those of you wondering "Why" regarding a different exhaust system for the -14, it's simple...the stock system is a 4-into-1 system and with a big IO-390, it will probably suffer some restriction due to not enough exhaust flow. The Vetterman system is a nice dual 2-into-1 system with 2 tail pipes, that is tuned and should give the engine better breathing. It also includes turned down pipes, to help keep the belly from being heated up. While I haven't flown with it yet, I expect the exhaust should do really well. I'm more concerned that the cowl exit area may be too tight and we may have to open that up a bit. Time will tell on that.
The exhaust system does provide dual heat muffs in hopes of keeping a nice warm cabin. While they aren't in place in these photos, I did use the same heat shields as Van's uses, in the area of the fuel flow sender and fuel lines. additionally there will be a heat shield on the pipe below the throttle cable.
My heat shielding will be shown in some photos regarding the throttle quadrant that I should have available by late this week.
The exhaust hangs off the back of the sump, and the tail pipes go up and over the nosewheel hinge point, and into the tunnel. If later it is found the cowl would need more exit area, it would not be too hard to route the pipes under the nose wheel hinge point, and keep that tunnel completely open.
The overall design kind of looks like modern art, to me.
Now on to the pictures. I'll break them down into multiple posts.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1375+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 300+ hours http://www.MyRV14.com
RV-10/14 Transition Training: http://www.RVCFI.com
Old 04-26-2016, 09:19 AM
Tim Olson - CFI
Old 04-26-2016, 09:20 AM
Tim Olson - CFI
Old 04-26-2016, 09:21 AM
Tim Olson - CFI
Old 04-26-2016, 11:05 AM
Be sure and let us know how badly the dual pipes bang the sides of the tunnel during startup and shutdown........
Other than that, the rest of the exhaust and cabin heat installation looks pretty much what is standard in the kit (except for maybe the aim of the hose ports on the Van's heat muffs are better for where each hose needs to go).
Scott McDaniels
Hubbard, Oregon
Old 04-26-2016, 01:31 PM
Clint at Vetterman's did change the angle of the heat muff inlet/outlets slightly after he did mine, so other people should have a more direct routing of the SCAT tubes. If I find a reason to some day, he'll swap them with me.
I'll be curious to see how the exhaust does with the tunnel walls too. There is a good amount of clearance there, actually, but, it's been a while since I've dealt with the 4-bangers. The IO-540 does a shutdown shake too, but I'm not sure if it will be harsh enough that it'll actually touch, on the -14.
The short of it is, I personally dislike the whole "Tunnel" idea on the -14 anyway. I think the cowl should have come down lower and the exhaust should come out the bottom just as it does on the -10. The tunnel itself is an eyesore from the bottom, and being made out of stainless, I don't think I'll paint it because the paint won't stick as well, and even if it did, it's going to have a hot exhaust pipe stuffed into it that would probably discolor the paint anyway unless there's plenty of airflow to prevent it. I guess we'll see after time.
Tim Olson - CFI
Old 04-26-2016, 06:13 PM
czechsix's Avatar
czechsix czechsix is offline
Default Tunnel / Exhaust Clearance
Thanks for posting those pictures Tim. I think Stoney Ware also has a Vetterman crossover exhaust in his -14, of course his doesn't have the nosegear structure to work around, but the pics on his website show the pipes dropping down out of the cowl completely below the tunnel. He had to cut openings in the cowl where they exit. See his pics at http://rvbuild214sw.com/.
I like the idea of keeping the exhaust going through the tunnel better as it seems like a cleaner installation, but I had the same thought as Scott looking at your pics that there's not much clearance there. The pipes on my -8A (which has a 'mini-tunnel') had a lot more clearance than that and they would still make contact with the underside of the tunnel at times...they move around a lot.
I wonder if Vans chose a 4-into-1 design because they thought it would improve performance, or if it was simply because it fits in the tunnel area better? It would be nice to get some performance comparisons between two -14s with the same engine/prop combination but with crossover exhaust on one and 4-into-1 on the other to see if there's any quantifiable difference in exhaust system performance.
FWIW I'll also mention that in contrast to Tim I really like the tunnel design. To me it seems like an elegant and efficient way to reintroduce the engine cooling air into the slipstream and it has less frontal area than it would if you had to further lower the cowl like on the -10 and the other side-by-side RVs. I often thought if I were to do my -8A over again I'd replace the cooling ramp with stainless steel both for fire protection and because it's less likely to crack than aluminum due to the constant pounding of exhaust pulses. And the fact that it isn't painted doesn't really matter to me because you never see it unless laying directly underneath the airplane...not a perspective most people have when drooling on your RV-14
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 05-08-2016, 04:12 PM
NorrisAir NorrisAir is offline
Default Exhaust diameter
Tom,
I like the looks of your exhaust system. One question, what is the diameter of your exhaust pipes. I am putting in a Superior XP400 so Van's system won't fit so I planning on a Vetterman.
Norris
Old 06-01-2016, 09:06 PM
KeithB KeithB is offline
I have also decided on a Superior XP400, now being built by Aero Sport Power. I called Vans regarding the Vans exhaust (i.e. will it fit?) and they have no knowledge/information, suggesting I contact Superior. Before getting Vans to delete the exhaust from my FWF kit, I'd like to confirm that it will not fit. Can anyone confirm this is the case?
Also, I see the Vetterman Exhaust installation post by TimO, but that appears to be on a 390, so I assume it was done for other reasons.
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, >375 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
Old 06-01-2016, 09:38 PM
Hot exhaust pipes stuffed into it
Is there any heat shield or insulation to keep the heat out of the cabin?
