Old 03-10-2016, 09:17 AM
Ahaa moment, now I get it about one of your prior photos.
The black bar "in front" of the gear is a bearing retainer. Correct?
Is the electrical connector from the Mazda distributor also?
Old 03-10-2016, 09:37 AM
DanH's Avatar
DanH DanH is offline
Correct.
No, it's an Amphenol AT series connector, interchangeable with Deutsch DT series. I really like 'em. High overall quality, and the terminals crimp to the wires just like an oversize D-sub pin. Even the tool is the same, but in a larger size.
http://www.waytekwire.com/products/1...AT-Connectors/
http://www.deutschconnector.com/prod...es_connectors/
As an old car guy, I know that most electrical problems are really connector problems.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-10-2016, 09:46 AM
Deutsch----------havent heard of them in a long time.
I was a machinist for Deutsch back in the late 60s.
Yep, connector or ground issue were 90% of the problems for sure.
Old 03-10-2016, 04:59 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Frankly, I like the OEM Ford module, as I figure it is far more hardened than any aftermarket control.
Are you sure about that? Some aftermarket stuff is certified, others have been third party tested for vibration, EMI/RFI tolerance for use in military UAV applications where expensive sensor payloads are at risk.
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 421 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 03-10-2016, 06:10 PM
DanH's Avatar
You're right of course. I should have said "far more hardened than any certified, military grade aftermarket control available for about $100 brand new".
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-10-2016, 06:35 PM
rv6ejguy's Avatar
Can't beat used OTS automotive hardware for the price point for sure.
With used, you could be fortunate that if it has lasted 10 years, it's going to last another 10 or 20 or unfortunate where a good portion of its life is already behind it...
Not all Ford electronics in the last decade have been great. The EDIS DOES have a good record in my experience and I especially approve of the ND pickups which are bulletproof in a fixed configuration- much more so than some other brands of OEM magnetic pickups which I consider unfit for aviation use unless you have two.
Some military applications are using COTS hardware/ software these days, well below the price range of Mil Spec electronics.
Old 03-10-2016, 09:33 PM
DanH's Avatar
Keep in mind that I'm not calling this a big success just yet. Let's fly it awhile.
BTW, not my first dance with OEM ignition parts. These are GM modules (actually NAPA TP45's), part of a dual ignition on a biplane in the 90's. Used ND reluctors for that one too. Fired two coils through an MSD coil joiner to single plugs. An earlier version was independent coil-per-plug. The really early version used Briggs and Stratton magnetos
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-10-2016, 10:25 PM
rv6ejguy's Avatar
Yeah we built stuff like this for race cars using HEI modules eons ago and it worked just fine with the junkyard parts which was all we could afford back then. Brought back some good memories here. BTW, like your machine work and the creative cover design.
Old 03-11-2016, 05:31 AM
6 Gun 6 Gun is offline
Smile crank gear
Dan the crank gear looks like a simple way to go will the pickup work also with 3/16 aluminum or does the pickup need steel.
Thanks Bob
Old 03-11-2016, 03:33 PM
rv6ejguy's Avatar
Reluctor wheels have to be made of ferrous material.
