Old 01-11-2016, 04:35 PM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
Default Ethanol Free Fuel Issue
I have been usng Ethanol free gas for two years as I have a service station close to my airport that carries it. Today on my refueling trip I noticed that the price per gallon had dropped almost $1 since last month, nothing close to the drop of regular gasoline. Looking at the pump more carefully I also noticed that the octane displayed for non ethanol was now 89 vs 92 last month. Indeed the appellation of this type of gas is now Plus vs Premium before. I discussed these changes with the owner who told me that their supplier is now receiving Ethanol free gas that is 90.1 octane and has he did not have stickers with this grade to put on his pump he applied the 89 one.
Now the question is: will my Rotax 912 ULS run on 90 octane gasoline?
After a search I found the following thread on the subject:
http://www.vansairforce.com/communit...ad.php?t=87540
I am reintroducing this subject because I suspect that what has happened in my area might also have happened elsewhere. If you are using ethanol free gas watch out next time you refuel your RV-12.
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 01-11-2016, 05:12 PM
You might get better response to this question if asked in the Rotax Forum.... http://www.rotax-owner.com/en/rotax-...ical-questions
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 333
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 01-12-2016, 04:04 PM
todehnal todehnal is offline
I think it depends on the supplier. I live in an area of Western Kentucky, near Kentucky Lake, were many station offer what they call boat gas. It is 89 octane ethanol free fuel, which is actually a blend of regular, and premium. I also have a local supplier who sells ethanol free 91 octane. I can get ethanol free 93 octane premium, but I have to drive 60 miles to get it. I do, and carry a 55 gal drum with me. According to that supplier, all of the fuel in our area comes from the same pipeline, located in Nashville TN. He says that only two grades are available, 87 octane regular, and 93 octane premium. He says that anything else is a blend, and that the ethanol is added after the pipe line distribution, not through it. The suppliers blend fuel strictly to lower their cost so that they can offer more competitive pricing. So far, I have been able to get 93 octane premium, but it is at a slightly higher price. For what this is all worth............Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 01-13-2016, 05:41 AM
f1rocket's Avatar
f1rocket f1rocket is offline
This is why I gave up on using ethanol free fuel. I just use 93 E10 and fly merrily on. It's more important to have the octane than it is to eliminate the alcohol.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 01-13-2016, 06:59 AM
N427EF N427EF is offline
Default Amen
Randy has it exactly right.
I cannot understand this crazy obsession with not wanting to use
E10.
As far as I know 93E10 is available everywhere and Rotax engines are approved for running on E10.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
Old 01-13-2016, 07:02 AM
Raymo's Avatar
Raymo Raymo is online now
E10.
Probably because of the shorter "shelf life" of fuels that contain ethanol. I imagine there are other technical reasons too but they've been hashed out on other threads as well.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 01-13-2016, 09:48 AM
funflying funflying is offline
Default Good to hear
The success of E10 fuels is good to hear about because getting the ethanol free, 91 octane, is a bit of a drive for me. In the good flying season I use it regularly and fly more frequent. Winter rolls in and I switch to 100LL because of the stability as the plane sits more.
I may start using the 93 E10 this summer and see how it goes.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 01-13-2016, 12:18 PM
Also, gasoline without alcohol has more BTU content. E10 has 96.7% of the energy of straight gasoline. Doubt if you'd notice...
Hinckley, Ohio
Old 01-13-2016, 12:35 PM
johngoodman's Avatar
johngoodman johngoodman is offline
I am not an expert on fuels, but I started out burning 93 E10 in my LS1 conversion. After 20 hours, I noticed a lot of build up in the filters. I bagged it and took it to a guy who sells 90 E0. He pointed out that it was the same stuff he found when he did a phase separation test. He showed me the test jar, and the same junk that I found was at his phase separation level. Turns out that the yellowish fibers are Corn Silks. The little brown globs are Corn Syrup. I switched over to 90 E0, and also use some 100LL on cross countries. Filters have been clean since then.
John
John Goodman - 40572
First flight was 25 June, 2011
N711JG
Old 01-13-2016, 01:35 PM
Take a look at the pictures of the fuel pump that was disassembled recently, and posted on this forum, which shows all of that interior corrosion in just 20 hours of operation, which might be another good reason to keep the ethanol out of your gas, in you can.
