  #51
Old 11-13-2016, 11:42 AM
czechsix's Avatar
czechsix czechsix is offline
Originally Posted by Av8rRob View Post
Good info thanks. I will delete the vans battery box and use the convertible one from earth x to give options. Besides moving the elt, another possibility available is buying a lighter weight tailwheel.
The tailwheel has about the longest moment arm on the airplane, so that's a good place to save a few ounces if you can. Also if you use a light coat of primer on the empennage and single stage paint (instead of base/clear) those things all add up. Another thing some people do is to add fiberglass to cover the gap between the empennage tip fairings and the aluminum structure. That plus several layers of high build primer to blend the tips seamlessly into the rest of the structure also adds weight (and time). IMHO a nice clean joint where the fiberglass tips meet the aluminum looks nice and it's easier and lighter weight too.
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 07-10-2017, 01:30 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default Updates
Anyone with one of the newer -14's flying care to share your w&b? This thread is getting stale with no new info.
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 07-10-2017, 06:43 AM
To the moderators,
As I am going to be doing a W&B shortly I took some interest in this thread. Early in the thread there was an error in a post that limited the aircraft potential. Even though the error was found later on in the thread, I believe that errors of this type should be removed for safety reasons and also some readers may be inclined to stop reading the rest of the thread at that point and discount the RV14 as not meeting advertised specifications.
We should all be very careful about posting any specific weight and balance numbers that are significantly different then the factory numbers. Typically big differences are measurement or scale errors.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 07-10-2017, 08:08 AM
n982sx n982sx is offline
Here is mine for N626KM, a 14A.
Note: No paint, wheel pants or fairings at this point plus I added a second battery, alternator and the accessories for them. Otherwise she is stock with a pretty full panel.
Empty Weight/CG....Weight (lb.).......Arm (in.)...Moment (in. lb.)
..Right Wheel..........439.............97.5.......42,803
..Left Wheel...........445.............97.5.......43,365
..Nose Wheel...........378.............40.0.......15,120
Empty Weight..........1262.......................101,288
Empty CG...............................80.3
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
