Old 01-10-2016, 10:56 AM
SabreFlyr SabreFlyr is offline
Originally Posted by Ron B. View Post
Any idea what was added for the extra weight from Van's #?
What did Van's -14 end up weighing empty. They don't have an empty weight on the spec page yet.
Ray Dosh
LJ45 driver
RV-14 QB #140212
VS, rudder & elevators finished
HS started
2017 DUES PAID
Marion, IN MZZ
Old 01-10-2016, 12:24 PM
MLock MLock is offline
I believe it was 1,232 lbs.
Mitchell Lock
President Van's Aircraft
Old 01-10-2016, 01:57 PM
Ron B. Ron B. is offline
Yes they do , first link on the opening post.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 01-10-2016, 02:37 PM
Not sure what you're referring to as the "opening post." I'm talking about this page:
http://vansaircraft.com/public/rv14specs.htm
Ray Dosh
LJ45 driver
RV-14 QB #140212
HS started
2017 DUES PAID
Marion, IN MZZ
Old 01-10-2016, 05:06 PM
Ahh, I missed the sample document. Just saw the quick reference charts.
Thanks!
Ray Dosh
LJ45 driver
RV-14 QB #140212
HS started
2017 DUES PAID
Marion, IN MZZ
Old 01-11-2016, 03:06 AM
control control is online now
If my 14 gets close to this, my wife an me can gain a lot of weight and still fly with full tanks and max luggage... not sure if that is a good thing
RV-14 kit #140138
working on FW forward and finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 01-11-2016, 08:05 AM
jswareiv jswareiv is offline
Default Weight Gain
Yes, but not sure if you will be able to get in and out. I am telling my wife "we" need to lose some weight and get in shape to get in and out of the plane easily.
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW
http://rvbuild214sw.com/
Dues paid to 2018.
Old 01-11-2016, 08:33 PM
czechsix's Avatar
czechsix czechsix is offline
Default Interesting...
Originally Posted by MLock View Post
Just weighed N914VA the other day. 1246 lbs. empty, w/o paint. Empty C.G came out at 81.38".
Will reweigh after paint next month.
Scott & Mitch, thanks for posting this info. A few comments/questions:
It's interesting that Mitch's -14A has a CG that is further aft (81.38) compared to the original prototype RV-14A (which came out at 80.61). I would have expected the opposite. Most significantly, Mitch's plane is unpainted...paint moves the CG aft, so an unpainted airplane should have a further forward CG. If the avionics in the panel area are heavier in Mitch's plane, that would move the CG slightly further forward. The G3X pitch servo is lighter than Dynon's, which would again move the CG forward. Something doesn't add up, unless the leather seats & bag compt upholstery weighs an extra 50 lbs or so. Is there anything else mounted in the aft fuselage on Mitch's plane (transponder, magnetometer, yaw damper servo)?
As a side note, the empty weight of the proto -14A on the https://www.vansaircraft.com/pdf/RV-..._SampleW&B.pdf worksheet doesn't equal the sum of the three wheel weights. 436 + 364 + 435 = 1235 lb (not 1239 as shown). I'm not trying to nitpick, just wondering if the discrepancy indicates any errors in the original data (which might explain the CG differences as well?).
The reason it matters is because if I use the data from the original -14A, I can put a Whirlwind prop on it and stay within aft CG with two average adults, full baggage, and minimum fuel. Using Mitch's numbers, I'll have to stick with the Hartzell otherwise I run out of aft CG unless I limit myself to less baggage or lighter than average pilot/passenger. And it'll only get worse after painting.
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 01-11-2016, 09:37 PM
Mark,
I agree with your assessment and can't explain the difference. It should be closer than the current data shows. The weight discrepancies (I will look into where the error got introduced) of N214VA are not enough to influence the C.G. position much at all.
N214VA has been weighed on digital calibrated scales a number of times in the past couple years. Each time there has been no surprise as to the result.
I am not sure what Mitch used for scales, whether the tanks were completely empty so that no compensation had to be done, etc...., but I would have expected N914VA to have been much closer to N214VA than it is. We will have to look into it, but my gut feeling at the moment is that there is possibly an error in the data for N914VA (it's C.G. is a small bit further aft than what the RV-14 tail dragger is).
So until further information is provided, consider the values for N214VA and N144VA to be the official examples.
Scott McDaniels
Hubbard, Oregon
Old 01-12-2016, 05:43 AM
kaber56 kaber56 is offline
Are you using an IO-390 or IO-360 in your tabulation?
