Go Back   VAF Forums > Model Specific > RV-4
Old 11-19-2015, 06:59 AM
Toobuilder's Avatar
My Rocket used the footwell box as the mount for the rear rudder pedals. The pivot was at the very bottom of the well, and the whole assembly came out as one unit when you removed all the screws. I removed the pedals almost immediately however, as the interface to the main rudder cables just wasn't very clean. Lots of rubbing and weird angles.
Michael Robinson
______________
RV-8 - Flying
Old 11-19-2015, 10:53 AM
Bill Dicus Bill Dicus is offline
Default Footwells
Agree with Axel. Never found rudder buttons in rear seat of RV-8 adequate for good control; after landing (from the back) I would ask the pilot in front to finish the roll-out. I wasn't comfortable doing that. It was his airplane!
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 12-13-2015, 07:06 PM
marv1121's Avatar
marv1121 marv1121 is offline
Foot wells were constructed from scratch and installed just a few days ago. They look good and make the rear seat much more comfortable. I got back there and tried them out, on the ground. Have not had a real passenger use them yet.
Thanks for all the good info, it made the project go very smooth.
Marvin Homsley
www.smoke-system-helper.com
419-360-7414
marvin@buckeye-access.com
Old 02-21-2017, 07:17 AM
exercise exercise is offline
Using the Cloud Dancer plans Smokyray linked to and the RV-4 Fastback Pics of Axel, I still can't tell if the sidewalls of the foot wells are to be riveted on the outside of the 90* bends in the V shaped flooring or on the inside of the bends? In other words, when one looks into the foot well, can the bends be seen?
THX, John in MN
RV4 salvage project
IO-320 C/S
hope to fly it in spring 2018
0601054 att gmaill dot comm
Old 02-21-2017, 09:59 AM
smokyray's Avatar
smokyray smokyray is offline
Default Nothing new under the sun...
Originally Posted by marv1121 View Post
I am interested in installing foot wells for the rear passenger. Has anyone done this before to their already flying RV-4. Are they the same ones that go in the RV-8 Do you make them yourself or buy them pre made from Van's. Any info would be helpful.
Marv/John,
This is an age old question that has been discussed many times over the years on this forum. A quick reference to the search tab above will yield a plethora of usable data on virtually any RV related (and various other) subjects.
Many years ago, Van queried early RV4 builders via a survey as to what we would change in the newly designed but yet unreleased RV8. Passenger foot wells was one of the top requests.
An early RV4 builder (Paul McReynolds) crafted foot wells for his RV4, printed a set of plans and submitted them to the now defunct RV8R newsletter. They can be found in the 24 years of the RV8R book I highly recommend for any non builder of the original RV's. My friend Steve Sampson was savvy enough to post them on his blog during the construction of what I believe is the quintessential RV4, G-IKON. Here is a link to the plans. http://3.bp.blogspot.com/_n0oPgd-_rr...h/HPIM0980.jpg
I built mine in a day of mild rivet work, cutting and fitting. Be careful that they are not too deep as the aileron pushrods will rub the bottom. One of the single best mods to the RV4 I made.
I added my own design rear rudder pedals that were basically stirrups that clamped to the rudder cables that folded out of the way or could be removed.
I considered my RV4 more like an RV3 with big baggage and not a dual control, instruct from the rear seat airplane, nor would I ever put anyone in the front seat who wasn't qualified to solo it. My 2 cents.
Rear foot wells are highly recommended. Just do it...
http://www.vansairforce.com/communit...ad.php?t=56247
VAF link to one of many threads on subject.
V/R
Smokey
Old 02-21-2017, 10:52 AM
Default Need some pics?
John,
You had your feet in mine when I took you for a ride last visit you made to NC! You forgot to take a picture didn't you!
Bill E.
RV-4/N76WE
41 Aeronca 65TC Defender
8A7 / Advance NC
Old 02-21-2017, 12:50 PM
About the only picture I took was of me grinning during my FIRST RV takeoff
THX, John in MN
RV4 salvage project
IO-320 C/S
