Old 11-11-2015, 08:15 PM
RV-9 Yellow Bird RV-9 Yellow Bird is offline
Default Best way to trim the rudder?
At cruise, my RV-9 flies hands off with the ball about half a diameter to the left, requiring left rudder to center it. I'd appreciate some guidance on how big of a wedge I need to glue on the rudder to correct it, and if somebody knows where I can get a plastic wedge kit rather than using a wood wedge.
Brian RV-9
Old 11-11-2015, 09:14 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
About 3/4 of one of these placed midpoint on the rudder addressed my trim needs when the ball was 1/2 out:
http://www.averytools.com/prodinfo.asp?number=9883. Hurry though b/c Avery is closing things up pretty quick.
I recently moved my wedge down to the bottom of the rudder where it is less obtrusive visually. However, since it is probably now partially blanketed by the HS and elevators, I find that I probably need a bit more of the wedge.
Long and short, decide where you want to locate yours and then just trim a little at a time until you find the right size to center the ball.
Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 11-11-2015, 09:52 PM
shamer's Avatar
shamer shamer is offline
Default Rudder trim wedge mounting method
To mount the wedge for determining its size, use scotch 3M temporary double side poster tape, the thin clear stuff just like Scotch Tape. It is strong enough to secure the wedge while you figure out how big it must be and is easily removeable for adjustments. Use new tape each time. Once you have finalized the wedge size, switch to the permanent Scotch 3M tape. It sounds hokie but mine has been on there for over 8 years using this tape.
This tape is very thin so the wedge fits flush to the rudder. Cleanliness is important and the area must be free of wax.
Steve Hamer
RV-6
Eagle, ID
Old 11-12-2015, 05:52 AM
Captain Avgas Captain Avgas is offline
Brian RV-9
Installing a trim tab on the rudder is treating the symptom rather than treating the cause of the problem. If the skid ball is out you obviously have a rigging problem that is causing asymmetrical drag and hence yaw. I recommend you start by taking a good look at your wheel and gear leg fairings to make sure they are in trail. It has been reported than an error of just 1/8" in the trailing edge of a gear leg fairing can cause a half scale deflection of the skid ball.
Regards
Bob Barrow
RV7A
Old 11-12-2015, 06:29 AM
HFS HFS is offline
Default Can You Say - Gurney Flap?
Look it up!
Gurney Flap - Wiki
HFS
Old 11-12-2015, 09:56 AM
Rupester Rupester is offline
Another vote here for the Avery rudder wedge approach. Cheap, easy, and effective. . Mine ended up as noted above ... About 3/4 of the original wedge length located mid span.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 11-12-2015, 10:02 AM
Bill Dicus Bill Dicus is offline
Default Gurney flap
Wow! Dan's a shirttail relation and I never knew he did that. Sounds worth a try on my left flap lower (?) surface to correct a 1/3 right ball in cruise. Has anyone on the site given this a try?
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 11-12-2015, 10:46 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Small world, the person who named it married an engineer who worked for me...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-12-2015, 11:20 AM
Default Gurney flap
Thanks Gil - neat to hear. My maternal aunt was Dan's mother's sister. Got to meet him only once but he is memorable. His accomplishments as a driver, builder and innovator are amazing. Interesting - his dad was a baritone with the Metropolitan Opera, reputed to do limericks and great jokes non-stop for 48 hours; quite a raconteur! Sorry - this is really peripheral. Hope someone enjoys.
Bill Dicus
Old 11-12-2015, 06:28 PM
HFS HFS is offline
Default Use of Gurney Flap
A -4 in Santa Paula (SZP) is using one now on his rudder - very effective, and not very big.
HFS
