Old 10-23-2015, 06:28 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Default Silent Hektik Voltage Regulator Install!
A little back ground on my setup. First flight was 2010. 2009 Rotax engine and Ducati voltage regulator. Dual Dynon D180/D100 screens, NAV and landing lights installed. My old voltage regulator lasted 758 hours at which time I was able to acquire a Silent Hektik(now known as SH) regulator from a friend who travels often to Europe. The old Ducati didn't develop much voltage at low power settings but at/above 5000 RPM it developed about 13.6 volts and at 2500 RPM it developed about 12.3 volts. Now with the SH at 5000 RPM it developes about 13.8 to 14 volts and at 2500 RPM it now developes about 13.4 volts. I installed the SH using the original installation setup as the Ducati with a few exceptions. First the 1/4-28 bolts would not work because there was not enough clearance along the side of the hole in the regulator to slide a socket over the head of the bolt. So I used a 1/4-28 socket cap screws instead. Second I went against the trend of using heat sink grease under the regulator and actually lifted it up about a 1/16 inch above the metal shelf by putting thick metal washers under the regulator bolts. I've spent a lot of flying hours in the 12 and that stanless steel firewall gets very hot. Inflight sometime try taking your shoes off and put your feet on the fire wall. Third I grounded the regulator directly from the battery as well as off the engine per Bill's suggestion. The SH is almost the exact same size as the Ducati. The holes need to be slightly enlarged for the 1/4-28 bolts but they line up perfectly with the original bolt pattern. The plug that holds the wires for the Ducati is exactly the same for the SH, simply unplug the Ducati and plug in the SH. The bottom of the SH is metal and the resin circuit board is completely in cased in the metal housing. The label on the SK says 14 volts 47A. So I'm not sure you will be able to get more amps out of the SH, maybe Joe Gores can address this. I won't be testing this because I won't be changing my avionics anytime soon. But I do think when only pulling 18 amps it won't create as much internal heat as the Ducati. The SH seems like a well built unit. Only time will tell, I'll keep everyone updated as we put hours on the unit. Here's a few pictures of the unit and install.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Jetguy@att.net
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 10-23-2015, 07:53 PM
Harvey rv12 Harvey rv12 is offline
Default where can i get one ??
Any hope of us other 12 owners getting our hands on one ??.
thx
Tom O.
Old 10-23-2015, 08:39 PM
rjtjrt rjtjrt is offline
Re sourcing Silent Hektik F4112 for USA, possibly this motor cycle trader in UK would source and ship them to USA.
http://www.motoguzzisales.co.uk/index.htm
They do ship another (different) Silent Hektik part all over the world according to their site. Possibly they could obtain the F4112 and ship to US?
Old 10-23-2015, 10:13 PM
The Rotax permanent magnet alternator (dynamo) is the limiting factor. If the dynamo is loaded to its maximum, it could get very warm. Excess heat will shorten its life. ASTM standards limit alternator output to 80 percent of its maximum capacity.
Joe Gores
RV-12 Flying
Old 01-20-2017, 01:36 AM
E. D. Eliot E. D. Eliot is offline
Default Your experience please
John, assuming that you have used this VR for more than one year, could you up-date this discussion with a report on ts performance so far? Sure sounds good.
Building finally
Old 01-20-2017, 09:02 AM
Jetguy's Avatar
The SH is still working great. I think I have over 100 hours on it.
John
RV12 N1212K
Jetguy@att.net
S/N 140014
Old 01-20-2017, 12:31 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
thx
Tom O.
Do a forum search.....there is a motorcycle shop in UK that will send them to US. That is where I got mine.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 01-20-2017, 01:27 PM
MacPara's Avatar
MacPara MacPara is offline
Dito. Mine just reached a 100 hours, too. Here's a write-up of my installation and the slight changes about the cooling that I made.
It is working flawlessly ever since I put it in.
RV-12: #120374, ELSA, N128TL flying since Nov 28, 2013 (Phase 1 completed 1/26/14)
SkyView, Light Package, ADSB
http://torstensrv-12.blogspot.com/
APRS Track
Old 01-20-2017, 03:37 PM
Jetguy's Avatar
Just got back from hangar, 204 hours on SH so far!
John
RV12 N1212K
Jetguy@att.net
S/N 140014
Old 01-21-2017, 02:54 PM
Dave12 Dave12 is offline
I just heard from the Moto Guzzi shop in the U.K. and they will ship the unit to the states. The price is $230 plus $50 shipping.
Proud Dad of a Navy Corpsman
FMF "Devil Doc" 2nd Marines
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying
