Old 03-05-2017, 09:04 AM
Carlos Trigo Carlos Trigo is offline
Default Lip thickness
Originally Posted by rleffler View Post
Having a 1/2" think edge is a red flag to me. I've not heard of that before. The thickest dimension on mine was about 1/4". Without seeing a picture, I would be concerned about how far back you cut. Otherwise Vans has done something new to the cabin cover mold.
A photo would help to all others to render better advice.
Here they are
https://www.wetransfer.com/downloads...5160146/981a05
You can see that, especially in the corners, the thickness is way bigger than the 3/16".
Should I file or sand the bottom?
Carlos
Old 03-06-2017, 05:43 AM
rleffler's Avatar
rleffler rleffler is offline
Originally Posted by Carlos Trigo View Post
Here they are
Carlos
You cut off a bit more than I did, which may explain the differences.
I would probably just sand the interior down to you get the 1/4" diameter to accommodate the seals. I would also recommend getting planearound.com strut brackets if you don't already have them.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-06-2017, 01:42 PM
Default Just like mine
I cut using Ivan's measurements and mine looked just like that. I bought a Permagrit burr and made a guide for the dremel to get a nominal 1/4" X 1/2" deep flange. Worked fine. And the Permagrit tools are worth their weight I. Gold when working on fiberglass...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 03-06-2017, 03:49 PM
Default lip thickness
Thank you to both Bob's
@Bob L
PlaneAround brackets, together with their third latch, were already ordered, actually they are just now crossing the Atlantic inbound Portugal (where I live and I'm building the -10 )
@Bob (rocketman)
I'm on my way to Google to find out what a Permagrit burr is ...
Carlos
Old 03-07-2017, 08:55 PM
Default Permagrit
Try here:
http://www.fibreglast.com/category/S...minate_Cutting
Bob
Doors - Done
On Gear
290 HP Barrett Hung
