Old 03-16-2017, 07:00 PM
Scott Millhouse,
Was there continuity between SkyView display pins 16/17/18/19 and the USB socket? The USB socket numbers 1,2,3,4 on Van's schematic do not match up with standard USB pinouts. That makes me wonder if the schematic is labeled wrong or if the USB socket is actually wired wrong. https://en.wikipedia.org/wiki/USB
Standard USB pinout:
1 RED +5 Volts 16
2 WHITE Data -18
3 GREEN Data +19
4 BLACK GND 17
Receptacle Picture:
Joe Gores
RV-12 Flying
John-G John-G is offline
Originally Posted by Bill_H View Post
You also need a USB stick inserted to take screen snapshots - and the downward facing port under the panel would be awkward (and likely result in a broken USB stick.)
Bill ... I too was worried about breaking the typical USB flash drive plugged into the USB port under the instrument panel (at this point mine is working flawlessly so continue to use it) and was lucky to locate some tiny PNY 32G flash drives. Picked up two of the ones shown in the photo below and rotate them every month as map updates come along. I placed a rivet next to the flash drive for a visual size comparison.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 03-16-2017, 07:10 PM
Are you sure it goes directly to the Skyview
Pretty sure. I suspect that the USB wires from the SkyView go into the backshell of the EFIS D-Sub on the AV-50000A. But the USB wires do not actually connect to the AV-50000A. Instead, they make a U turn, come back out of the backshell and connect to the USB receptacle. That is my unverified theory. You can check it out yourself by taking the backshell apart.
Joe Gores
RV-12 Flying
Old 03-16-2017, 07:12 PM
skydiverlv skydiverlv is online now
Originally Posted by scottmillhouse View Post
Are you sure it goes directly to the Skyview? Check drawing 42C-02 that shows it going to the 50-pin D-Sub "EFIS" that connects to the AV-5000A. That is the way it looks by following the wires when the Skyview is removed.
I see what you are looking at. It is a visual anomaly. Reference the Vans Skyview schematic and you will see a direct termination to 16,17,18,19 of the 37 pin Dsub at Skyview. I had to run wires from my co pilot Skyview for USB to update new versions to second screen.
Larry Vandegrift
ULPower 260is, dual ECUs, dual 30 amp alternators
Old 03-16-2017, 09:19 PM
PilotBrent PilotBrent is offline
Originally Posted by KALEWIS View Post
I noticed that the supplied usb would work, then sometimes not. If you look on the back of the skyview, there are 2 other USB ports. I got a 3 foot extension cable, and ran it from the back of skyview into the map box. No more issues. I drilled a hole large enough in the map box and installed a rubber snap bushing for the usb cable. Simple.
Me too. Works great.
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
Hobbs over 400 hours and on second set of main tires!
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
