Old 05-09-2015, 06:37 PM
kritsher kritsher is offline
Default Bad USB port
My Skyview doesn't seem to recognize USB drives inserted into the port below the panel. I've tried with two different USB sticks, both of which work fine in multiple PCs.
One the drives has an LED indicator on it which lights up when it gets power. With this stick, the LED flickers as I insert it into the plane and if I move the drive around in the port, but it doesn't stay on long enough for the Skyview system to recognize the drive. I assume I have a bad USB port in my plane. I haven't yet opened up the panel to see if the other USB ports in the Skyview are working.
Has anyone else ever seen this happen?
Does anyone know the best place to start looking for a replacement USB port part? Van's? Dynon? Stein?
Ken
RV-12 #359
N1769K
6B6 - Minuteman Field, Stow, MA
Old 05-09-2015, 07:54 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
I noticed that the supplied usb would work, then sometimes not. If you look on the back of the skyview, there are 2 other USB ports. I got a 3 foot extension cable, and ran it from the back of skyview into the map box. No more issues. I drilled a hole large enough in the map box and installed a rubber snap bushing for the usb cable. Simple.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 260 Hrs on the Hobbs
http://unicom12.blogspot.com/
Click on above for build site
Old 05-09-2015, 11:44 PM
rgmwa rgmwa is offline
I put a USB port in the panel just above the screen. Bought a 9" USB lead on eBay and plugged it directly into the back of the Skyview. Cheap and works well. I recall others saying that the standard port mounted under the panel seemed to be a bit temperamental. Mine's installed, but I've never used it.
rgmwa
120346
Old 05-10-2015, 01:13 PM
Thanks guys! USB extension cable on order.
Ken
RV-12 #359
N1769K
Old 05-10-2015, 01:24 PM
Bill_H's Avatar
Bill_H Bill_H is offline
I had the same experience (intermittence of the panel connector - even got a replacement one from Stein) and did the same extension cable solution. I routed the cable into the glove box. I leave a USB stick in it all the time and at the end of each flight I download the logs.
You also need a USB stick inserted to take screen snapshots - and the downward facing port under the panel would be awkward (and likely result in a broken USB stick.) My keyring has a small USB stick on it for loading software updates.
Should I ever go to two screens, I would take short extension cables from each and route them to under the panel, but snugged with cable ties so they would point horizontal rather than vertically down.
Bill H, RV12, N412BR "Sweetie", Skyview-equipped, Call sign Robot
Old 05-10-2015, 04:50 PM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
Same problem.
I installed two short usb panel mount cables (cheap on eBay);
PH-BZT
MyKitlog
Picasa pictures
Old 03-16-2017, 04:01 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
Default Unrecognized USB port
I have had the exact same problem as expressed with the Skyview not recognizing the USB thumb drive with the under panel port for software updates. The ones on the back of the Skyview work fine. Bought a new USB port from Stein and spliced and soldered it in. Did not fix it. Vans said check continuity from pins 16/17/18/19 on EFIS. Looks like it is not EFIS but the catch all AV-5000A box that the harness connects to. I'm scared to touch that again since when new the stall horn did not work and I had to have my plane down for about a month while they repaired it. Anyone dive into this enough to determine if this is another AV-5000A box problem? I'm out of warranty now and I trust Stein more than that box so I'm going with the USB extension wire unless someone knows a fix without having Vans repair the box.
Scott- 2018 dues paid
Got medical back, now building a 7A.
RV-12 #120515, 319RV over 220 hours.
1st flight 12/08/15, flew SNF, Oshkosh, Triple Tree & SERFI in year 1!
RV-9A, 536 hours, sold, RV-7 sold, Kitfox sold
Old 03-16-2017, 04:34 PM
skydiverlv skydiverlv is offline
The USB is connected directly to Skyview. There is no connection through the AV5000A
Larry Vandegrift
ULPower 260is, dual ECUs, dual 30 amp alternators
Old 03-16-2017, 05:06 PM
Are you sure it goes directly to the Skyview? Check drawing 42C-02 that shows it going to the 50-pin D-Sub "EFIS" that connects to the AV-5000A. That is the way it looks by following the wires when the Skyview is removed.
Old 03-16-2017, 05:49 PM
dent dent is offline
Default usb port
If you buy a extra usb port ext. , make sure its a USB 2. I tried the USB3 cable and it did not work. The USB2 cable did.
