Old 02-20-2015, 09:32 PM
erich weaver's Avatar
erich weaver erich weaver is offline
Checked my NL starter today. LOOSE! Tab washers were in place.
There is a problem here folks. Everyone should check theirs.
Erich
Old 09-16-2015, 12:37 PM
tim2542 tim2542 is online now
Default Failed again
Yeah mine has come loose again after 49 hrs, bolts pulled, lock tabs still in place. I'm not sure whether to send it in for warranty or just install some tine-serts myself, or buy a B&C.
Tim
Old 09-16-2015, 12:55 PM
BillL BillL is offline
Tim
If you don't send it for warranty how are they going to learn? It is not a flight risk. Put inserts in the new one.
Edit: Or . . Work with them to figure it out. Others might benefit too, and you won't have to experiment solo.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 09-17-2015, 06:21 AM
WA85 WA85 is offline
Over the past 25 years of working on Lycoming engines I have seen many of the in line type starters with loose case bolts and weeping a grey "grease like" substance. A theory explained one day was that the starter motor house experiences small amounts of torque during starting and the long through bolts get twisted slightly, which eventually leads to fretting as the housing gets looser and looser. Not sure how true this is, but this is a fairly common issue.
Old 09-17-2015, 09:33 AM
jjconstant's Avatar
jjconstant jjconstant is offline
Hmmm...I've absolutely noticed this repeatedly and repeadtedly tightened the bolts. I put torque seal on the heads and noticed it cracks so there definitely is some loosening going on. Mine did not come with any locking mechanism other than star style lock washers. I remove the phillips head bolts/screws, put new star washers under it, tighten and torque seal. At first it seemed like they loosened with fewer hours, as time has gone on it seems I have to do it less, though I don't know if it's associated with the number of start cycles. I haven't been able to fly as much recently
It would be great to have a more reliable solution...
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2018 paid plus some for those who can't
Old 10-24-2015, 10:17 AM
g zero g zero is offline
Default Starter
Pulled the cowl to change the oil and give everything a good look . The Skytec Starter was making a mess , sent some pics to SkyTec . They want the starter back for warrantee . Guess they know about the issue and want to make it right .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 10-24-2015, 05:13 PM
scard's Avatar
scard scard is offline
Just back from the hangar, working on a condition inspection. Skytec NL with a few hundred hours on it completely loose between the halves. Full on "jiggle, jiggle 3/32" between the halves with locking tabs still in place. I'll be interested to hear Skytec's comment.
Scott Card
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
Track
Old 10-24-2015, 06:01 PM
I would not expect full disclosure, just warranty.
Someone should measure the bolt length each time it comes loose. It may be yielding instead of pulling out the threads. That would help those out of warranty narrow the failure mode, and effect a durable repair. These should be pretty high strength bolts, maybe they came from a non-heat treating country.
Edit: I guess this goes on the oil change check list?
Bill
1st Flight 1-27-18
2017 Dues Paid
Old 10-24-2015, 06:19 PM
1001001's Avatar
1001001 1001001 is offline
One trick might be to remove the bolts one at a time and reinstall them, preheating them first. Depending on the material of construction of the bolts, the bolt length difference due to thermal expansion can be very precisely calculated. Heat the bolts so they are maybe 0.0005"- 0.001" longer than cold, then install them.
Steam turbines are often assembled this way, to create a sealing pressure between the two halves that varies less when the casings and bolts heat up and expand.
Old 10-25-2015, 10:53 AM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
Default tab washers
Does anyone know what's the part number for those tab washers?
Lenny
