Old 08-29-2014, 11:58 AM
DeltaRomeo's Avatar
Your host.
Exclamation SERVICE BULLETIN 14-08-29
http://www.vansaircraft.com/pdf/sb14-8-29.pdf
VAFDR
doug reeves. N617AR. RV-6.
First Flight: 9/14/02.
Track me: KG5PRB
Old 08-29-2014, 02:25 PM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
Wow, not the easiest fix if you have cracks!
Troy Branch
RV10 Built and Flying Since Feb 2009
850hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid 2017
New Family Travel (B)Log: http://www.amateurbuiltfamilyfun.com
Old 08-29-2014, 08:45 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Tell me about it
Vans have the SB kits but no nose strut parts…
Gounded for 5-6 weeks
Better than a accident on a runway somewhere I guess
______________________________
David Brown
The two best investments you can make, by any financial test, an EMS and APS!
Old 08-30-2014, 03:55 PM
Jesse's Avatar
Jesse Jesse is offline
That's exactly right. It would be interesting to know just how many -10's have cracks and how many hours they had when discovered. So far we only know of 2 cases, I think, with many that don't have cracks, even with over 1,000 flight hours. It would be interesting to know how close together the two with damage were manufactured.
352-427-0285
jesse@saintaviation.com
Old 08-31-2014, 08:01 PM
BlackhawkSP's Avatar
BlackhawkSP BlackhawkSP is offline
Originally Posted by DeltaRomeo View Post
I guess I'll be calling Van's Tuesday for the doubler. Mine isn't even on the gear yet, so I've dodged this bullet.
Larry Anderson
Indianapolis
RV-8 N88XT Flying
RV-10 QB N38LA Flying
Helicopter Instructor Pilot
Standardization I.P.
Instrument Examiner
U.S. Army Retired
EMS Pilot for LifeLine
At IU Health
Old 08-31-2014, 11:00 PM
jeffwhip jeffwhip is offline
I've got a question for everyone. If I haven't ordered the finishing kit or firewall forward kit, does this effect me?
Old 08-31-2014, 11:46 PM
dhmoose dhmoose is offline
From the Service Bulletin itself:
"Engine mounts shipped after August 13, 2014 are not affected by this service bulletin."
So, you're ok.
David Halmos
Flying - 420+ hours and counting!
Portland, OR
2018 - Dues paid
Old 09-01-2014, 06:42 PM
rdoerr01 rdoerr01 is offline
It was time for my 50 hour oil change, so I took this opportunity to inspect the Nose Gear on my RV-10. My RV-10 now has 1140 hours on the Hobbs, about 5% of my landings are on grass runways, some even have rolling mounds like in Port Elgin, Canada (CNL4). I always keep the nose off the ground until full aft elevator won't allow it.
I was glad to see and report that mine doesn't have any cracks in the mount where the donuts rest up against it. However I did see the bolt that goes between the donut shaft and the nose gear legs had signs of wearing. Also the two bolts that hold the gear leg to the mount in two places were also showing signs of wear. I'm going to go ahead and replace these bolts while I'm at it.
Ray Doerr
N519RV (40250) Hobbs=1140
Old 09-01-2014, 08:54 PM
aerhed aerhed is offline
That looks pretty good. More like you'd expect, don't you think?
Actual repeat offender.
Old 09-01-2014, 11:11 PM
RV10inOz's Avatar
Ray, You have similar hours and I agree we have some wear in the bolts and bushes, again most likely accelerated due to the rough surface issues. We are replacing them all.
I think the high frequency hammering the elastomer plate cops on an uneven surface is considerable compared to a bitumen runway.
It will be interesting to watch over the next 1000 hours how this develops. It will be an annual inspection item from here on.
David Brown
