Old 08-10-2014, 06:35 PM
caapt caapt is offline
Angry Aileron Bell-crank Binding
Any one else have this problem? When I tork them down (85 inch/lbs) they bind up severely. The bellcrank is shorter than the brass bushing and even when they bind I can slide them up and down the bolt.
Any advice?
Old 08-10-2014, 07:43 PM
longranger's Avatar
longranger longranger is offline
I had a similar problem with my RV-7 bellcranks. The inside bores were a bit rough at the welds, so I honed them out slightly with sandpaper taped to and wrapped around a dowel.
I also had a problem with a Dynon roll servo bracket that was misdrilled from the factory, causing the pivot bolt to bend slightly when torqued, and bind in the bellcrank. Dynon replaced the bracket at no charge, and the problem went away.
Hope this helps!
Miles (VAF# 1238, Paid up as of 12/2016)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on order
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 08-11-2014, 08:24 PM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
Originally Posted by caapt View Post
Any advice?
Have Vans send you a new one if it is binding up because of the bellcrank bore.
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 08-12-2014, 06:39 AM
jlfernan's Avatar
jlfernan jlfernan is offline
You don't need a new bellcrank. When they are welded the welds intrude into the tube the bushings fits into. Use the appropriate sized drill bit or reamer and clean out the welds inside the tube. This a very common issue.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 08-19-2014, 10:34 PM
Smile mystery solved
Had my DAR take a look. The brass bushing (tube) is slightly bowed. Same problem with replacement tubes. By rotating the bushing in place we found a position that allowed free movement for that part of the arc that the bell crank needs to travel. Still binds up beyond that.
Old 08-20-2014, 11:14 AM
KCBerner's Avatar
KCBerner KCBerner is offline
Does this solve the problem? Is there any chance that it could become repositioned later and bind in flight?
Forgive me if I'm being an idiot, I'm trying to understand better for my own learning curve...
K.C.
RV-14A #140026
Wings 70%. Started on the Emp.
www.KCandAshleyBerner.com
Happy to be a 2016 =VAF= contributor
Old 08-20-2014, 09:48 PM
petersb petersb is offline
Any advice?
If this is a brass bushing inside the weldment it is caused by the ends of the brass bushings not being square. When the bolt is tightened the brass bushing bows
RV7A New Dec 2013 - 360, C/S, slider
RV6 - 1600 Hours ---- Sold
Old 08-21-2014, 06:55 AM
DaAV8R DaAV8R is offline
Default Bellcranks
I had this problem but determined that it was a function of the steel brackets not being bent exactly 90 degrees. A good way to check this is to assemble the brackets, bushing and bellcrank on the bench and check for free bellcrank movement and parallel legs on the steel brackets. Mine were great on the bench but would drag when installed on the spar.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 08-21-2014, 08:32 AM
Default 3rd set of bushings in the mail
Talked to vans. They are sending another set of bushings. We are at a loss. Bellcrank has been reamed. Brass bushing is longer than bell crank. All are binding.
Old 08-21-2014, 06:43 PM
rapid_ascent rapid_ascent is offline
I had a problem with mine binding once it rotated past a certain amount. Vans said to sand the interior but that didn't seem to help. I ordered a new one and a new bushing to see how those work. I was thinking that my bushings might not be square on the ends. I sanded them to final length on my HF 1" belt sander so they probably aren't perfectly square on the ends.
I may try to rig up some sort of fence thing to keep it square. I'm not sure if this has anything to do with my problem but hopefully with the options I now have with the new parts I can get it to work correctly.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
