Old 07-06-2014, 09:59 AM
MartySantic's Avatar
MartySantic MartySantic is offline
Default Van's RV-12 Notification 14-07-03 - All METAL Locknuts
Reposted to make it easier to find during a forum search.
Van’s Aircraft recommends that owners and/or operators of all RV models comply with the applicable recommendations in SAIB HQ-14-16 per Van's RV-12 Notification 14-07-03.
http://www.rotor.com/rotornews/April14/HQ-14-16.pdf
From the parts lists. Found that Van's supplied 29 locknuts for my RV-12.
Empenage Kit
Bag 2671 6 - MS21042-6
Fuselage Kit
Bag 2720 6 - MS21042-08, 2 - MS21042-3
Wing Kit
Bag 2624 2 - MS21042-08
Finish Kit
Bag 2772 2 - MS21042-08
Avionics Kit
Bag 2801 1 - MS21042-3
Powerplant Kit
Bag 2812 9 - MS21042-3, 1 - MS21042-4
Spent a little time looking. Found all of them BUT one. If someone finds it in the plans, please let all of us know! Keep in mind, my plans are 4 years old, so Van's may have re-numbered some of the plan pages.
RV-12 MS21042 Metal Locknut Locations
Empenage Kit
Page 11-06 - Trim Motor Attachment to Tray (6)
Fuselage Kit
-08 Page 21-20 - System Block Stud Bolts (6)
-03 Page 23-07 - Vent Doors on Side of Fuselage (2)
Wing Kit
Page 16-04 - Ground Wire to W-1205 Bracket (2)
Finish Kit
Page 38-09 - Cowl Closeout Bracket
COULD NOT FIND the 2nd Maybe the parts list is in error?
Avionics Kit
Page 42-11 - DG Clamp for GPS Wires
Powerplant Kit
-04 Page 46-16 - Starter Motor Ground Connection
-03 Page 45-03 - Battery Ground to Battery Tray
-03 Page 49-09 - Water Radiator Door Push Pull Cable Clamps (3)
-03 Page 49-17 - Oil Cooler Line DG Clamp
-03 Page 49-05 - Water Radiator Bolts (2)
-03 Page 49-12 - Oil Cooler Bottom Guide Bolts (2)
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
Old 07-07-2014, 11:02 AM
Found a few others by doing a .pdf word search on all of the page revisions that Van's has posted.
For those with later kits, the locknuts are used in the Skyview/Transponder installation, the new fuel pump drain line, the new fuel tank vent line, the new canopy latch microswitch. They may be used elsewhere in the lighting kit which I do not have.
They are also used in the very first iteration of the fuel tank lexan window (which were removed with new new lexan window in the S.B.).
If anyone has a complete set of plan pages in .pdf format, a complete search would be trivial. I only have the pages that have been revised.
Anyone have a COMPLETE set of plans in .pdf??
Davenport, IA
Old 01-03-2015, 06:10 PM
Phantom30's Avatar
Phantom30 Phantom30 is online now
Vanís Aircraft recommends that owners and/or operators of all RV models comply with the applicable recommendations in SAIB HQ-14-16 per Van's RV-12 Notification 14-07-03.
Empenage Kit
Fuselage Kit
Wing Kit
Finish Kit
Avionics Kit
Powerplant Kit
Empenage Kit
Fuselage Kit
Wing Kit
Finish Kit
Avionics Kit
Powerplant Kit
How about the one securing the fuel tank vent line clamp backside the bulkhead rear of the fuel tank?
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 07-15-2015, 08:53 AM
AeroDog AeroDog is offline
I'm unsure what we're supposed to do to comply with this. Are we supposed to track down every lock nut and replace it? How do we know if the lock nuts we've used are defective?
Jerre
Empennage and fuselage kits complete
Wing kit compete, Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2018
