Old 02-07-2017, 08:52 AM
JHartline JHartline is offline
Default Notches?? What notches?
I'm looking through my revisions and can't find the reference you mention to notch the cover ribs. I'm well past that stage anyway but I don't like the thought that I've missed something. I'll be installing my harness soon.
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
Old 02-07-2017, 09:29 AM
n982sx n982sx is offline
Default Fuselage harness and micro molex
Originally Posted by salto View Post
Hope I notched big enough. 👍
If you still have access, notch them a little bigger than the plans suggest. I notched mine per the plans and the connectors would not go through. My fuselage was complete when I got the harness last July and it was a pain to enlarge the notches in place.
I wouldn't try removing the pins from the micro Molex connector. Micro Molex pins can be removed with a removal tool but, according to Molex, the pins are no longer good and you need to put on new pins.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 02-22-2017, 09:04 PM
Tom023 Tom023 is offline
Default Cover rib panel drawing
The drawing on page 28-11 figure 2 incorrectly shows the F-01435A panel's top flange resting on top of the cover ribs. All other drawings in various chapters show correctly the flange tucked under the top flanges of the cover ribs.
RV14A #140083
Wings, empennage and fuselage slow builds completed
Finish kit in progress
2017 Donation
Old 02-22-2017, 10:51 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Which kit contains the main harness you are referring to? Finish?
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 02-23-2017, 12:00 AM
I was referring to the Main Wire Harness 14/14A Kit, Van's part number ES WH-00125 KIT, which is an option. It is not included in any kit. If you are going to order it, order it with the fuselage kit so that you can install it as you build the fuselage.
It is not too hard to install after the fuselage is assembled but it will be a lot easier to install while building. I was very disappointed that it did not come standard with the fuselage kit as the wiring did for the wings and empennage.
On the download page, there is a drawing of the harness and it is detailed enough that you could make your own that would interface with the wing and empennage harnesses.
Bob Meyers
Last edited by n982sx : 02-23-2017 at 08:09 AM. Reason: Added part number for harness
Old 05-07-2017, 10:01 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default 38-26, Step 3. Breaking Canopy Frame Skin Slot Edges
38-26, Step 6 - calls for breaking the lower edges of the slot that the front lower corners of the canopy slide in to (shown in Figure 1).
This is hard to do at this stage without buggering-up the glare shield because it is hard to get to. Do this edge breaking before you get to this stage, maybe back around page 38-20 before you are handling the canopy plexiglas and have got a nice paint finish on your glare shield.
Had painted the canopy frame glare shield skin twice, nice finish; and the back frame arch C-01405 was painted. Moving the plexiglas around to get it far enough away from the edges that needed breaking.
Jeff Warren
Simpsonville, SC (SC47)
1946 Bellanca Cruisair 14-13-2 (71 YRS OLD 8/15/17)
RV14A (N14ZT), Ser#140195
Start 10/11/14
IO-390 Lyc Tbolt / CS Hartzell
Dues paid 12/1/17 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 06-22-2017, 04:02 AM
control control is offline
Another insignificant finding:
Fuselage page 29-10, figure 5.
Figure 5 is showing the F-01413 stiffener. Either I am not seeing it correctly or it is showing the right stiffener, not the left one as stated in the plans.
RV-14 kit #140138
working on the finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 06-22-2017, 09:31 AM
It is the L part that is depicted. A primary clue is to look at the end of the part on the far right. If it was the R part you would see the edges of the part depicted (but they are not).
Scott McDaniels
Hubbard, Oregon
Old 06-24-2017, 04:11 PM
Had to look at it many times before accepting that I was wrong, I just got the direction of the bends in the plans wrong.
RV-14 kit #140138
Old 07-10-2017, 04:57 AM
Almost got fooled again...
Maybe not an error but do check Figure 2 on page 29-15 including the detailed view on F-01461A-L. Compare this to Figure 4 on page 29-20 showing the same part in what I think is a correct rendering (showing the lines on the bottom of F-01461A-L)
RV-14 kit #140138
