Old 03-19-2017, 03:54 PM
rzbill's Avatar
rzbill rzbill is offline
Originally Posted by rv8ch View Post
Carl, is that some kind of tubing around your CHT probe wire?
They look the same as my CHT probes that came with an integral wound spring strain relief.
Mine came from GRT but I image available from plenty of other sources.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 690hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 03-19-2017, 04:00 PM
dave4754 dave4754 is offline
Default WOW!!
That is the most amazing tool, the 360 firewall forward view of the RV 14.
I have been trying to figure out fuel lines and the manifold for oil pressure , oil temp, and fuel pressure and bingo there it is and you can magnify it as well.
Wow thanks for pointing that out Scott and OP I am in the same place as you so thanks for asking the question.
Dave
Dave Cobb
=VAF=2018 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complere
Fuse nearing completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 03-19-2017, 08:58 PM
Originally Posted by RV6_flyer View Post
Thanks for posting that. I love the 360-view images. Wish they had that 25-years ago when I was building my RV-6. Was very lucky to have a Pawnee getting a new engine several hangars away to look at for planning my -6 setup.
Dave
Credit for the 360 views and detail photos goes to Adam Burch..... former Van's employee who has moved on to higher endevors (spacecraft )
Scott McDaniels
Hubbard, Oregon
Old 03-20-2017, 11:24 AM
gasman gasman is offline
Did you notice that Van's uses an oversize alternator pulley.
VAF #897
2017 =VAF= Dues PAID
Old 03-21-2017, 10:10 AM
carlrai's Avatar
carlrai carlrai is offline
Default Mickey
No sir. It's part of the assembly that bayonets into the CHT port on the side of the cylinder. Included with GRT's probes.
http://www.grtavionics.com/EISandAcc...s10-2-2013.pdf
Carl Raichle
Lutz, FL
RV-9A N194CR
Based at KZPH
AA4SR
Old 03-21-2017, 10:50 AM
rv8ch rv8ch is offline
Originally Posted by carlrai View Post
No sir. It's part of the assembly that bayonets into the CHT port on the side of the cylinder. Included with GRT's probes....
Got it - thanks for the info.
Mickey Coggins
http://rv8.ch
Old 03-21-2017, 10:59 AM
Both airplanes in the photos have a standard / right out of the box Plane Power alternator.
Scott McDaniels
Hubbard, Oregon
