Old 03-06-2017, 08:34 AM
Rupester Rupester is offline
Put in both. If you install just one, you'll be kicking yourself after just 6 months.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 03-06-2017, 11:22 AM
Joe Parish Joe Parish is offline
Here is a link to the post about reinforcing the steps. I sent mine in. Very happy with the results. http://www.vansairforce.com/communit...d.php?t=134249
Russ posted in another thread to check in to USPS has something online called Click-N-Ship that can save you money over Fed-Ex or UPS.
Joe
RV-9A N525XC
Flying as of 5-4-18
Last edited by Joe Parish : 03-06-2017 at 11:26 AM. Reason: Put in shipping details
Old 03-14-2017, 06:55 AM
boandrv7a boandrv7a is offline
When I got the 7a it only had one installed. I had a second installed on the pilot side. It was a PITA and expensive to have the second installed (I'm sure most around here could do the work, so it would probably be cheaper/easier).
I definitely would recommend the second step!
Jim
The AV8R's
Old 03-14-2017, 09:50 AM
rzbill's Avatar
rzbill rzbill is offline
Originally Posted by Mel View Post
Just always be aware to assure that both are not used at the same time.
+1 !!! Diane and I learned the hard way. Fortunately we jumped off in time before the tail hit the ground.
Very careful about that now.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 710hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 03-14-2017, 09:52 AM
grubbat's Avatar
grubbat grubbat is offline
Default Steps
I didn't install any on my -9 and sometimes wish I had of. Seems like to me, given the history of cracking, that this is one area that could be improved somewhat besides the welded gusset. Maybe a removable step or one without all those rivets on the outside. The design works but it's ugly. 😄 Both steps on my -6a cracked out. Resonance frequency does some weird things. Rambling done.
Craig
RV-3 Sold
RV-6a Sold
RV-9 IO-360 CS, Flying
1967 Twin Comanche C/R, Flying......
Old 03-15-2017, 01:53 PM
As others have said... Always one at a time!
Ask me how I know...
The AV8R's
Old 03-15-2017, 02:07 PM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
Mine had one. I added the other one.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017 donor and happy to do it.
Old 03-15-2017, 04:21 PM
catmandu's Avatar
catmandu catmandu is offline
I have one, and I don't use it. Tens of passengers, never an issue not having one on that side of the plane, except for those over 80, where I doubt the step would have helped enough (used a step stool).
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
