Old 03-13-2017, 05:56 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Some pics to help out:
Originally Posted by scsmith View Post
In the glider world, the spherical ball connectors are colloquially referred to as Heim joints.
There are two types of locking feature found on Heim spherical ball joints. One is a safety pin like a diaper pin inserted through a hole in the release bar that prevents it from being depressed to release the joint.
Safety pin through the lock plate:
The other is a threaded collar that when backed out on its thread to the end covers the bottom of the release bar and prevents it from being depressed. In both designs, the release bar is spring loaded to keep it 'latched' but is not fail safe without the safety.
Wedekind Sleeve:
Carl N.
Arlington, WA (KAWO)
RV-8, 300 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel H-201B Standard Libelle, N564NS - Sold
Old 03-13-2017, 07:47 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Do these have anything to do with Heim per a previous posting?
I've always seen them referenced by the German names - with this example from a Schempp-Hirth FAA AD
This document clarifies information in Airworthiness Directive (AD) 97-08-06 that applies to Louis L'Hotellier S.A. (L'Hotellier) ball and swivel joint quick connectors installed on gliders and sailplanes that are not equipped with a "Uerling" sleeve or an LS-safety sleeve.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-13-2017, 08:05 PM
RV8JD's Avatar
Being a sailplane pilot also, I've always referred to them as L'Hotellier connectors. I was just adding the pics to help with Steve's word description of the safeties used on spherical ball connectors he refers to in Posts #2 and #10.
Here is a good description of the different types of safeties used on the L'Hotellier connectors:
http://aviation.derosaweb.net/wedekind/
Carl N.
(Pic 1),(Pic 2)
(Pic)
