Old 03-04-2017, 05:56 AM
Reflex Reflex is offline
Default How did you do that? ( Tight Space Rivet)
I seem to be running to to a few areas that need some special attention to complete. The latest spot is the rivet closest to the trailing edge at the top of the rudder. The plans call for a MK-319-BS pop rivet to be put in place.
As you can see from the pictures below, there appears to be no room to get the second one in due to the lack of room. What's baffling to me as in searching this site, it looks like that I'm the only one having trouble with this spot. This makes me believe that I've done something in the wrong order or.....I'm just plain stupid. Both are distinct possibilities!!
The pictures below depict the problem. I expected to have a problem with the last rivet on the bottom side, but this one surprised me.
Thoughts?
Fred
Dues Paid for 2018
RV-14
Working on Empennage
Old 03-04-2017, 06:02 AM
rzbill's Avatar
rzbill rzbill is offline
Very slowly pull the rivet. As it gets shorter, keep pushing the flush head into position. It will come out fine.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 710hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 03-04-2017, 06:37 AM
Tom023 Tom023 is offline
Not that it solves your problem but on my build the bottom rivet causing the interference is a solid rivet and sits lower giving a tiny bit more room for the pulled rivet. That's probably why I didn't seem to notice the clearance issue. As Bill said you will be fine.
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed
FWF and avionics in progress
2017 Donation
Old 03-04-2017, 07:34 AM
Yup, after getting everything in place, I realized that I could have indirectly driven a solid rivet on one side giving me a bit more room. Too late now as the plans state that the hole in the R-903 rib should be drilled out to #33 before installation. Now to big for a -3 solid rivet. Hate to go to an oops rivet as it means drilling again and taking another step toward creating a "point of no return" mess by drilling a larger hole.
Fred
Dues Paid for 2018
RV-14
Old 03-04-2017, 02:18 PM
Default Mandrel
In the picture it looks like the mandrel is too far down. Maybe if you pull the mandrel back into the rivet it would seat better before you start squeezing.
Thank you
John S
Fuselage started
Old 03-06-2017, 08:41 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Have you considered drilling out that driven rivet below that is holding things off? Then pull the top rivet. Then buck the lower one again.
Not sure about the order of riveting called for, or that was done, but it seems to me had you started at this tight end first and worked your way toward the more accessible rivets you could have had more room to get to these rivets in this section while the skins were still unattached down the line.
Just thoughts from an armchair quarterback.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
Old 03-06-2017, 08:44 AM
ppilotmike's Avatar
Solid rivet on one side, squeezed to the max that tolerance will allow, to get it pretty flat (no hole yoke helps here), then ease in a pop rivet on the other side.
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/15/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
