Old 02-02-2017, 05:18 AM
WVM WVM is offline
Default Rear spar doubler plate
Hi,
I am trying to understand the countersinck & rivet schema for the "Rear wing spar". For the W-907E Rear spar doubler plate I noticed this picture on a builder website:
But based on the plans it looks like that the second row on the right also need to be rivetted, isn't it?
If you appear to have detailed pictures from these rear spar countersinck and rivet setup, kindly share them with me. thanks!
RV9 #92188 - Working on wings
Old 02-02-2017, 06:10 AM
KazooRV-9A KazooRV-9A is offline
Here's some pix from my wing.
Old 02-02-2017, 08:06 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 02-03-2017, 04:30 AM
WVM WVM is offline
Many thanks! It is clear now.
Old 02-04-2017, 06:21 AM
WVM WVM is offline
I noticed that you both did a different thing for the spar flanges.
In the manual they say "Drill the holes to final size (#40) and dimple the upper spar flange along the length of the W-907B. When the spar is assembled, getting to these holes with a set of dimple dies is quite difficult (Fig. 7-1.)"
So I understand that I only need to dimple the upper flange. I suppose because the doubler plates are in the way when rivetted together. But further more I notice on figure 7.1 that this image also shows a dimpled lower flange.
What is suppose to be done?
And for the 3 outer holes in W-907E nothing is mentioned in the manual, also not in further sections. I understand based on the rivet icons on the plans that they are indeed 426 rivets. But if they instruct to prime the part and you have to countersink later it looks like they forgot to mention it.
Old 02-09-2017, 11:38 AM
gsxphil gsxphil is offline
The lower flange of the rear spar will get dmpled later after you match drill your wing skins.
For the rear spar doubler plate (907E) the 5 holes are for the aileron attachment brackets. There's a piece of angle that gets riveted there. I believe just AN470 rivets, so not countersink necessary.
The outer 3 holes get the AN426 rivets. After you match drill the rear spar to the ribs, then you can countersink the 907E.
Old 02-10-2017, 04:27 AM
WVM WVM is offline
Many thanks Phil! Have a nice weekend!
Old 02-21-2017, 03:15 PM
Neal Trombley Neal Trombley is offline
Originally Posted by mikehoover View Post
Mike
What Primer is that,,
Thank you
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
Old 02-22-2017, 10:36 AM
mikehoover's Avatar
Originally Posted by Neal Trombley View Post
Mike
Thank you
That is Dupont Variprime. If I had it to do over again I'd use a water based epoxy primer. Variprime is some nasty stuff to work with.
Mike Hoover
Columbia, SC
www.eaa242.org/
