Go Back   VAF Forums > Main > Safety
  #61
Old 05-16-2018, 02:42 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Off topic, but regarding MKII eyeballs....
Do you still need reading glasses? Or glasses of any kind?
May need something done this year, considering all options....
Chris Smith
Maule M5-180C
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Orlando, FL
Old 05-16-2018, 10:09 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Default MK II Eyeballs
I'm probably not the best one to offer advice since I was highly myopic all my life, so not all of the lens options were available to me. Because of this I was not a candidate for Multifocal lens implants, so I went with Single-Focus lens implants set for far distance in both eyes.
I now have 20/20 distant vision. I do need reading glasses for close up work, but I find that it's not an issue. For flying I have a pair of those stick-on readers on my sunglasses set perfectly for the RV-8's panel.
The website below (from the company who did my surgery) has a lot of good info on the whole process and the lens implant options offered.
http://www.pcli.com/treatment_for_ca...taract_surgery
Note that the FAA has different waiting periods before flying again after surgery: for Single-focus lenses (~ 3 weeks for proper healing) and Multifocal lenses (minimum of 3 months to allow for accommodation to the multi-focal lenses). My Ophthalmologist had no problem filling out the FAA form "Report of Eye Evaluation" attesting to my successful surgery, healing, and resulting vision. He cleared me for flying about 2.5 weeks after I had each eye done. At my next FAA physical, my AME accepted the FAA form "Report of Eye Evaluation" as completed by my Ophthalmologist.
See this AOPA article:
https://www.aopa.org/go-fly/medical-...racts-contacts
Not sure exactly how this would work with BasicMed.
Hope this helps.
Carl N.
Arlington, WA (KAWO)
RV-8, 300 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel H-201B Standard Libelle, N564NS - Sold
Old 05-17-2018, 11:09 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Hope this helps.
Good description, Carl. My logic and results were the same as your experience. After wearing glasses for nearsightedness since age 12, I now have 20/20 distant vision and wear reading glasses when I need them. My optometrist surprisingly didn't try to sell me readers; he just told me to pick up a pair of $9.95 readers at the local big store. Clear vision after surgery is one benefit of getting old.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/APRS Automatic Position Reporting System
“Certainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
"It should be added that the sublime beauty of the facture brings within the realm of discourse the substructure of critical thinking. " -using Doug's Art Critique jargon link and my birthday, I get this!
Old 05-17-2018, 11:41 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
If you are just now getting to the age where you need help with reading/close vision but don't otherwise need distance vision correction--and if you are flying under BasicMed--you might consider a "monovision" solution where one eye is used for distance and the other eye is used for reading. Although this is not acceptable for first-, second-, and third-class medicals, I was pleasantly surprised to see it approved (per primary care physician's concurrence) on the BasicMed application. I hate to wear regular glasses, and since my distance vision is good, I just use a contact for reading in one eye. LASIK on just one eye for reading is commonly done as well and would potentially be an even better solution. Google "monovision" and you'll see what it's all about.
Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 05-18-2018, 09:36 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Pet Peeve
Bottom line here is that most won't read the entire thing.
My pet peeve is the popular, "any other traffic please advise." Don't know where or how this started. It is annoying!!! Highlighted in this Circular.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N707EE-Building
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 05-18-2018, 10:57 AM
KleensRV6's Avatar
KleensRV6 KleensRV6 is offline
Default Use All the Tools
Originally Posted by rvbruce View Post
You can quote rules all day, argue procedures and right-of-way situations until you turn blue (i.e. No one is listening anymore). You really HAVE to be heads up, situationally aware and courteous. Slow down in the pattern and just try to enjoy the pollen in your eyes while your burning that expensive Avgas or Jet A.
This says it all, and don’t think your ADSB is going to give you the full picture because that NORDO dosen’t have a transponder. Head up and on a swivel. Provide your reports clear and concise.
Jailbird/CW Kleen
RV6 KGIF
Donor through 2018
