Go Back   VAF Forums > The Never Ending Debate Section > Polishing your RV
Old 05-16-2009, 05:06 PM
cjensen's Avatar
cjensen cjensen is offline
Default Okay all you polish guru's...I have a question
Calling all polish guru's!! I have Nuvite F7, C, and S. Here's what my skins look like to start...I roughed up the rivet lines with maroon scotchbrite long ago because I thought I would paint.
Here are several pics after two passes with F7...see the problem? These are all pics of the same spot...
Close up...
Nuvite sent me some sample sizes of other grades. The next course grade down from F7 is F9. So I tried that, and pretty much got the same result...
Everything but the rivet lines looks fantastic so far...I need some help here because I really want to polish...
Chad Jensen
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 05-16-2009, 06:05 PM
tomwebster's Avatar
tomwebster tomwebster is offline
It looks like you need to
do the compounding step.
See 'step one', below:
http://www.perfectpolish.com/QuickGuide.htm
The PerfectPolish web site has a lot of good info,
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Luscombe 8A/E (sold after 35 years)
RV-7A N462TW (315 hours)
CX4 (under construction)
Friends of the RV-1 http://www.rv-1.org/
Old 05-16-2009, 06:11 PM
Capflyer's Avatar
Capflyer Capflyer is offline
I had similar areas and what I found helped was to get to the point of wet sanding with 1500 grit sandpaper then use the F9 abrasive polish, then F6, then S. It really made a difference but I still cannot get it perfect.
Mike
JAMES AIRCRAFT.com
Recently Completed & Flying - RV8 Hot Rod
Flying - RV8
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 05-16-2009, 06:20 PM
cjensen's Avatar
That is the compound step...F7 and F9 with the compounding buffer-straight from the perfect polish website...
Chad Jensen
Old 05-16-2009, 06:44 PM
Wes Hays's Avatar
Wes Hays Wes Hays is offline
Chad,
I am certainly no guru, but I did stay at a Holiday Inn last night.
I just helped a friend polish a hummelbird. We had to wet sand the grain out of the aluminum (not alcad) and get rid of some deep scratches. Some of it we did rough up with some scotchbrite and in order to get it to polish, we had to sand the scratches out with 400, then 600, then 1500 then 2000 before it would polish. It was extremely labor intensive as you can imagine, but it did finally polish out.
I feel your pain, it is not fun.
Wes Hays
Winters, TX
RV-6A Flying 900+ hrs
RV-7A Fuselage
Old 05-16-2009, 06:49 PM
n144sh n144sh is offline
Eventually it will come out but takes work. I did exactly the same dumb thing many years ago - scotchbrite rivet lines. It will come out.
Steve
Old 05-16-2009, 07:54 PM
cjensen's Avatar
Steve
Any thoughts on what grade to use? F7 over again several times?
Chad Jensen
Old 05-16-2009, 08:21 PM
4kilo's Avatar
4kilo 4kilo is offline
Hate to have to tell you this Chad, but after two passes of F7 you are just getting started. 6 or 8 is usually a bare minumum, and 10 or 12 is closer to the mark.
Occasionally I have used coarser grades, but at this point I have pretty much settled on compounding with F7, cyclo'ing with F7, and finishing with S on the cyclo. I pretty much don't use anything else, and even after the F7 cyclo the finish is pretty good.
The plane Grady just finished on Friday is mine.
Pat
Pat Tuckey
RV-8
Superior IO-360, Hartzell blended airfoil, GRT dual screen EFIS
Flying 1400 hours
Formation Acro SAC Card
FFI flight lead
25XS (Waxahachie, TX)
Old 05-16-2009, 09:29 PM
cjensen's Avatar
Pat
This is great info Pat!! Being that this was my very first shot at this, I was worried that this wouldn't come out. I'll give it another 4 or five passes with F7 and go from there.
How much are you using? I'm putting about a fingertip's worth on each side of the pad, then smearing over the area, then an inch per second at 1650 rpm. Haven't run the cyclo over it yet...
Also, how often are you reapplying? After each section? Every two sections? I've just about memorized the info on the Nuvite website, but first hand info is always best!
Chad Jensen
Old 05-16-2009, 09:31 PM
frankh's Avatar
frankh frankh is offline
Default Polish?
Sorry I'm English so I can't help...
