Old 10-19-2019, 11:42 AM
Karetaker's Avatar
Karetaker Karetaker is offline
Default -7 Fuselage Stringer Placement
Hello crew. Looking at how the lower stringers on the -7 lower fuselage interact with the F-779 Tail Bottom Skin. Do the stringers fit between the side skins and the -779 skin or do they only lay over the -779?
If the stringers lay over the -779 skin, there seems to be quite a step as they transition from that skin to the -773 Side Skins.
Much obliged.
Mike
Vans RV and Pietenpol Channel
https://www.youtube.com/channel/UCna...sOaZYjSWIGeXlQ
Old 10-19-2019, 02:58 PM
wirejock's Avatar
wirejock wirejock is offline
Much obliged.
Not sure what you mean by "stringers". What stringers?
The bottom skin (778) has a formed set of J-channels.
From outside to inside at the 710 bulkhead rivet line...
Side skin (773) is outside, Bottom skin (778) is next, Aft tail skin (779) inside then bulkhead (710).
There are two J-channels but they go through the bulkhead so they are inside the skins.
Hope that helps.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/03/2019, plus a little extra.
Disclaimer
Old 10-19-2019, 05:19 PM
Karetaker's Avatar
"In aircraft construction, a stringer is a thin strip of material to which the skin of the aircraft is fastened. In the fuselage, stringers are attached to formers (also called frames) and run in the longitudinal direction of the aircraft."
I believe we are on the same page, just slightly different lingo. The Vans prints call them F-786C J Stiffeners.
Thanks for your help.
Mike
Old 10-19-2019, 05:55 PM
wirejock's Avatar
Default J-Stiffeners
Ok. Thanks for the clarification. Do you still need help?
Larry Larson
Estes Park, CO
Disclaimer
Old 10-19-2019, 06:06 PM
Karetaker's Avatar
No sir, thanks. It helps to take a break, have some chow and then re-read the written instructions.
Mike
Old 10-20-2019, 08:30 AM
rapid_ascent rapid_ascent is offline
In general I find it best to stick with the Vanís naming convention for parts when requestioning help on the forum. At times being even more explicit with part number can be helpful too it you know it.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
