Old 03-18-2018, 05:37 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Sorry, Powerwerx
12v meters and USB chargers 😊
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 03-18-2018, 06:18 PM
gblanck gblanck is offline
Default blue sea
This one has been working well for me, seems to charge better than the 2.1A adapter Spruce sells.
https://www.amazon.com/Blue-Sea-Syst...s=blue+sea+usb
Greg Blanck
RV-8 Completed March 2014
Redwood City, CA
RV-8 Build Log
Old 03-18-2018, 06:56 PM
climberrn climberrn is offline
Default +1 for Powerwerx
Had some older style from Stein, but have both failed at different times. As always, Stein was very helpful but they no longer carry the size I have cutouts for in the panel. The Powerwerx ones failed in my OV incident, but they are pigtails that hang down under the panel.
Most importantly, Id stay with the round cigarette lighter size, or the pigtail hanging under the panel. In the future, if one fails, you wont be locked into a particular design.
Joel
N626JA
RV-7A at CXP
Flying!
Old 03-18-2018, 07:18 PM
Northernliving Northernliving is offline
Ditto Greg. I'm also using the Blue Sea. Amazon's price is 2/3 of what others are charging.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 03-18-2018, 07:50 PM
N941WR's Avatar
N941WR N941WR is offline
This has worked out well for me. For $12.50 I thought I would give it a try.
No, I do not hear any noise in my headset and am happy with it. Also, you need to wire the USB ports to your master as they are powered, even when nothing is plugged in. The cigarette plug is on my "Always Hot" buss and I can charge my battery with it. (Although, I have a plug inside the oil door for doing that.)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-19-2018, 05:31 AM
catmandu's Avatar
catmandu catmandu is offline
Another vote for the Blue Sea 1045. Proven RF noise reduction, used one in my
truck when other 5v 4.2a chargers caused issues with the TPMS.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 03-19-2018, 09:53 AM
Snowflake's Avatar
Snowflake Snowflake is online now
Thanks everyone for all the replies. I found the Blue Sea Systems ones on Amazon (along with a lot of others) but wasn't sure how they might affect radios...
Originally Posted by Mike S View Post
https://www.steinair.com/product/usb...power-charger/
"For 12 volt and 24 volt DC electrical systems, 2.4 amps max.
Two 5 volt 2.4 amp USB power jacks with an LED indicator."
Originally Posted by TShort View Post
Or these, higher amp rating:
https://www.steinair.com/product/dual-usb-panel-jack/
"For 12 volt and 24 volt DC electrical systems, 4.8 amps max.
Two 5 volt 4.8 amp USB power jacks with an LED indicator."
What needs 4.8A? I've found that a 2.1 to 2.4A charger will keep one of my Tablet/Phone/Stratux running quite happily. 4.8A seems like overkill? I don't want to limit myself, but don't want to carry capacity I can't use, either...
I've seen them reviewed somewhere and seem to recall Stein mods them somehow for noise. I'm putting 2 in the upgrade...
Maybe if Stein sees this they can comment and let us know if both chargers are modified for noise... I would be happy with the rectangular one if they are. And i'd want three for my install... :P
Rob Prior
Old 03-19-2018, 10:33 AM
koupster's Avatar
koupster koupster is offline
Default Blue Sea 1045
The Blue Sea 1045 Maximum Output Current is 4.8A DC (total). You could pull 4.8 amps from one socket or 2.4 amps simultaneously from both sockets.
https://www.bluesea.com/products/104...r_Socket_Mount
Cheers, David
RV-6A A&P
Old 03-19-2018, 03:34 PM
dcl dcl is offline
Default Panel mount usb
http://www.charge4.co.uk
I saw these online, designed to be panel mounted. They appear to be intelligent in order to supply the correct current.
David
David
RV9A wings under construction.
Old 03-19-2018, 06:01 PM
Jvon811's Avatar
Jvon811 Jvon811 is offline
I second (third, fourth?) Blue Sea Systems...
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Best is, if you're a Carling Rocker Switch guy (Rockerswitchpros.com, Aveo Rockrack, etc...) this fits in the same hole and matches everything else.
This is a pic of my panel I just finished for my -4. The USB outlets are on the far right.
-Justin
RV-4 N249P O-320, Dual P-Mags, Warnke Prop, GRT Sport EX
