Old 05-18-2019, 11:15 AM
Michael Burbidge Michael Burbidge is offline
Default GPS Antenna Doubler?
I'm installing my ADS-B GPS Antenna on the top of the fuselage in front of the vertical stabilizer. I'm questioning whether or not I need a doubler. The skin is very rigid back there and the antenna very flat. There's no leverage to generate a bending motion. I'd rather not put rivets in my nice paint job.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying–340 hours!
Last Donation: December 2019
Old 05-18-2019, 01:18 PM
pa38112 pa38112 is offline
I made a backing plate that was roughly 1/3 larger than the antenna. I put rivet nuts on it and screwed the antenna into it such that it and the antenna sandwiched the skin.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 05-18-2019, 10:20 PM
Bugsy's Avatar
Bugsy Bugsy is offline
Default Me to
I am switching my GPS from inside mount to on top in back same as you and also plan to use a piece of aluminum as a backing plate without riveting it to the skin. Kind of like a big washer held in place with lock nuts.
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 05-19-2019, 04:23 AM
plehrke's Avatar
plehrke plehrke is offline
Do you have a sliding canopy? If so, are You putting it on centerline behind slider track or off to one side and the canopy slides over the top of it?
To OP, I would use a doubler plate as skins are thin and any point mass attached locally will work on them with high potential of skin crack at the fasteners. Plus you potentially get a better ground plane for better antenna performance.
Philip
RV-6A - 13 years over 900 hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 05-19-2019, 04:54 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Glue
Glue the doubler on with 3m 2216 or equivalent. You will get some vibration damping in the process 👍
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 05-19-2019, 05:42 AM
mturnerb mturnerb is offline
I did the same except used nutplates, and backing plate roughly same size as antenna (squared off corners and added space for nutplates) - see here: https://turnerb14a.blogspot.com/2018...-antennas.html
When I paint the airplane I'll bond antenna and doubler but for now just held in place with screws - torqued to Garmin specs of course.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
Old 05-19-2019, 07:40 AM
mountainride mountainride is offline
I made my own. Garmin sells one for $50. I will rivet it in today. On the question of nutplates vs nuts, once I finally get my window installed the GPS will still be removable by one person.
RV-14 N303XC : Flying
Old 05-19-2019, 03:44 PM
I haven’t drilled the holes in my skin yet. I started wondering if there were any structural issues with drilling a 9/16 inch hole in the skin of the tail cone. I ended up sending an email to Vans, but have’t heard yet.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 05-20-2019, 01:11 PM
Default Vans Tech Support Response
Here's the response I received from Vans.
"We haven’t tested it but it seems unlikely that a small hole there would be a problem."
Not the definitive response I was hoping for. I guess I'll look for another place to mount the antenna. This is by far the most convenient place for my setup.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 05-19-2019, 07:41 AM
Red Mtn flyer Red Mtn flyer is offline
Default i promised myself not to do this but
PLEASE go read 43.13. The nut plate method described does not transfer the loads, resulting in local stresses in the skin - which in your case is a STRUCTURAL MEMBER. The bonding method MAY be sufficient: how were the surfaces prepared? Was there a test model? Was that article tested to failure? Was the application methodology tested [temperature/ compression/ clamping]?
There are some metal to metal bonding methods that work, obviously, and have been for some time. BUT -- I have seen some otherwise great systems fail when used in the field.
Sorry, but this would not pass my inspection. Touch up paint is a lot cheaper than replacing a fuselage skin that cracks - or fails.
Ben K.
A&P; RLSA - A,G,W/S Falco F-8L
50 yrs of flight and counting
Dues paid 2017 thru 2020
