Gregg,
The original RV4 plans called for the canopy skirt vents but most of us
Jurassic builders (especially us Southern Boys) discovered rather quickly in summer months that they didn't work well. Even after tufting them and installing VG's they are minimal cooling at best to this day. There was a very recent post on this very subject BTW, Tom posted a link above or...
search NACA vents.
As previously mentioned, the fuselage is a much better place to install them, 6" below the permanent aft cowl bump at a 2 degree down angle to the 0 degree waterline. (canopy rail is close to zero)
Another great idea is to install Larry Vetterman's flip out vents sold by Van's now.
http://www.vansaircraft.com/cgi-bin...rowse=heatvent&product=ventilation-components
Purchase two, install them 6"below the canopy rail 8" aft of the fwd fuselage bulkhead and one aft of the roll bar at the same height for your pitters. Spendy but worth it.
Want less holes showing on the pretty airframe? Cut the NACA vent into the bottom of the aft cowl bump and plumb the SCAT into the cockpit cutting a hole through the fuselage into the cowl cheek. Alot of work but works great when completed. For the aft cockpit, purchase the Vent Kit from Van's and install another NACA hole on the underside of the right wing aft of the spar and plumb it into the rear cockpit
ala RV-8. Works very well on the 4. Lots of airflow from both and nearly invisible when parked. Lastly, the RV-10 flip out vents work very well and close flush, good for keeping cold air out during your chilly Yankee winters...
V/R
Smokey
PS: Installing any of these requires some basic sheet metal skills, if you're a buyer not a builder or don't have tools or the "skills to pay the bills", stop by your local EAA chapter and ask for some help. You will find lots of new friends if you haven't already
