Wing to fuselage wiring connections?
Subwaybob
What kind of connectors would you use that will stand up over time for wing and tail to fuse connections? I want to completely finish the wings and emp then put them on and connect when it's time for the ride to the hangar from the home shop. I hardwired my 7 and don't want to do that again. Anderson power pole etc?
(BTW I plan to use dielectric grease on the connections)
I?m using mil 38999, but that is because I have some. I would guess after ?none?, most people will suggest CPC type.
