Old 07-15-2019, 10:54 AM
lr172 lr172 is offline
It’s a nice day in northern Ohio today so I took an hour flight. I have uAvionix echoUAT with iPad running ForeFlight. I show targets on the iPad even sitting on the ground because I’m locating in “B” airspace. Once in cruise flight I zoomed out to check for weather and saw none even with tropical storm Barry moving up from the gulf coast. Weather finally showed up about twenty minutes into the flight. FF showed ADS-B as good and ground towers and traffic appeared right away but weather was much delayed to populate the screen. I have seen this in the past so today I paid closer attention and it seems to be as I describe above.
Anybody else see this?
radar data is sent only every few minutes (maybe less, but not constant like traffic data) for regional and CONUS is sent every 10 minutes, I think. Not all EFIS units will process the CONUS data. My GRT doesn't
N64LR
RV-10 in Phase I
Old 07-15-2019, 11:44 AM
BobTurner BobTurner is online now
Which model GRT? My HX certainly does process the data for the whole US.
That said, it shouldn’t take 20 minutes, as long as you’re receiving a ground station.
Old 08-20-2019, 10:22 PM
charosenz's Avatar
charosenz charosenz is offline
Default echouat with sentry?
My apologies if this is a bit O.T. but I was surprised when I was looking at the UAvionix website that the list of compatible GPS on the site does not list the Sentry. Is anyone using the Sentry and foreflight with the Echouat from UAvionix?
I am considering this set up but want to make sure they are all compatible and it means more to me to hear it from been-there-done that folks..
Charlie
Old 08-20-2019, 11:26 PM
SPX SPX is offline
Charlie
Sentry cannot be used as a GPS source to the echoUAT.
Sentry cannot be used simultaneously with eachUAS to feed ForeFlight because echoUAT uses WiFi, just like Sentry does, and WiFi does not allow simultaneous connections.
RV-9A, Fallbrook Ca (L18)
Paid, Jan 2020
Old 08-21-2019, 12:58 PM
charosenz's Avatar
SPX,
WOW, thank you very much for the info.
Charlie
Old 08-21-2019, 03:49 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Echo from uAvionix uses its own Skyfx
for its GPS position source for the UAT "out", sniffing the transponder signal. Echo will output weather and traffic "in" by WiFi or wired connection to EFIS. I have that setup and my AFS 5600T uses the wired connection and I receive the WiFi to my iPad and iFly 740 -- I have WingX and FlyQ and iFly on my ipad -- they all work great with the uavionix setup.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 08-21-2019, 11:45 PM
SPX SPX is offline
Ron
Yeah, there really is no need for Sentry if you have an echoUAT...
Paid, Jan 2020
Old 08-22-2019, 11:24 AM
I have an HXr. I have zoomed out and looked numerous times and never see more than a couple hundred miles. There is always an edge with everything around it with hash marks.
N64LR
RV-10 in Phase I
Old 08-22-2019, 12:07 PM
Thermos's Avatar
Thermos Thermos is offline
The radar data is binary: if looking within 250 nm of your position, you should get higher definition. If more than 250 nm, you get the larger pixels.
This is a function of ADS-B FIS-B's weather data transmit scheme. Ground stations broadcast higher-definition radar returns only in the area they're located in order to save bandwidth.
Dave Setser
RV-7 skin, bones, muscle, heart and nervous system complete...down to the last 1 percent
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
