Old 06-08-2019, 11:32 AM
Kevin Handley Kevin Handley is offline
Default Vans gascolator
Hi all
I started to-remove the cowls with a view to inspect the engine bay
And thought it would be a good idea to clean out the gascolator
But it proved to much of a challenge for a novice like myself I twisted
And pulled the bowl but it did not move and I was a little worried about damaging it and thought if I do eventually get it off can I successfully reseal it so I have ordered a new I ring from vans just in case
Any advice from you guys would be appreciated
Old 06-08-2019, 02:24 PM
noelf noelf is online now
The gascolator provides a great seal against the "outside" air. As such, you need to activate the fuel drain on the bottom of the canister to allow air to enter as you remove the bowl. Otherwise you are fighting a vacuum that you are creating as you try to remove the bowl.
Noel
RV-6A N6NF
tip-up
flying
Old 06-08-2019, 04:44 PM
tomkk's Avatar
tomkk tomkk is offline
What he said. I have found it's still difficult to remove and I've found those rubber disks found in the kitchen to remove caps from containers to be useful to grip the gascolator body.
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 06-08-2019, 06:52 PM
Make a "T" handle out of pipe fittings and screw it into the bottom port. That handle gives you something to grab hold of to pull down.
Joe Gores
RV-12 Flying
Old 06-08-2019, 07:47 PM
alexe alexe is offline
Same as Joe said. Remove the drain fitting, then use a short piece of pipe to wiggle the bowl down and out. Works great. Having a spare O ring gasket on hand is a great idea. I managed to butcher (pinch) one putting the bowl back on.
Alex
Alex Erdelyi
RV-9A Purchased
RV-12 Built and Sold
Paid through December, 2020
Old 06-09-2019, 06:06 AM
Default Gascolator
Thanks all for your help
Kevin Handley
Old 06-09-2019, 06:54 AM
AirHound AirHound is offline
Try just running the fuel pump with screws removed and see if that helps!
Doug
Old 06-09-2019, 11:28 PM
I replaced the drain valve with one that locks open (please spare me the safety issue breast beating, Iím smart enough to check it closed after sampling). That eliminates the vacuum lock, but itís still a bit of a chore to remove it.
Old 06-10-2019, 07:31 PM
Driftdown Driftdown is offline
Originally Posted by RFSchaller View Post
. . . . ďIím smart enough to check it closedĒ . . . .
Last famous words. . .
Old 06-10-2019, 08:14 PM
If you canít cope with machinery donít try to operate it!😜
