Go Back   VAF Forums > Avionics / Interiors / Fiberglass > APRS Tracking
Old 04-25-2014, 09:38 PM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
When I am flying in the mountains of NH and Maine the track is very spotty. Few repeaters and iGates. I will test it in AK this summer I doubt it would have much usefulness there.
Vlad, change the configuration to Wide 1-1, wide 2-2, which will give you more secondary stations when farther from civilization. Just remember to turn it off or reconfigure when in very populated areas (I got a nasty email when I flew over to the SF Bay area once with it configured like this and was hitting all sorts of stations and "clogging up" the system - now I turn it off when in those areas). When I first set mine up, it was configured with default settings and in remote areas of NV it was not getting a signal out. Since changing to the new settings, I rarely have any issues getting a signal out in the lower 48, and have been trackable in some pretty remote areas of Yukon:
http://aprs.fi/#!mt=roadmap&z=11&ts=...all=a%2FN7965A
I suspect that in much of Alaska unless you're scud running, you will get signals out. That may not extend to the Aleutians, but certainly most other places.
Greg
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 04-26-2014, 12:02 AM
Pdtofly Pdtofly is offline
Default APRS and SkyView
Ralph,
Easy. Connect the APRS as follows. Connect the APRS RS-232 input to any unused SkyView serial port transmit. Then configure the serial port on the display appropriately under SETUP MENU > SYSTEM SETUP > SERIAL PORT SETUP, SERIAL PORT x SETUP > selecting the desired output data format. You need to select NMEA (GPS) Data Output.
If you use the Byonics MTG-RTG and have a position on your SkyView, check the light next to the power plug. It will turn steady green when it has a position lock.
You should only have three wires, power, ground, and GPS data in.
Good luck and if you have anymore questions, feel free to email me directly at hr2plt@yahoo.com
Brian
Old 04-26-2014, 05:02 AM
FA50driver FA50driver is offline
Default APRS
I would be interested in getting this, is there a website or someone I can contact who can run me through what I need? I already have my Technician license so the hardest part is probably done. Feel free to contact me at fa50driver@yahoo.com
Matt
ML
KZPH-Zephyrhills, FL
RV6 sold
RV6 sold
RV3 sold
2020 dues gladly paid!
Old 04-26-2014, 06:00 AM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
Matt
Matt,
You are already at the best source of aviation APRS information. Read the stickies at the top of this forum:
http://www.vansairforce.com/communit...play.php?f=104
Read this one first:
http://www.vansairforce.com/communit...ad.php?t=27773
Then work your way through the other stickies. Let us know if you have more questions.
Happy trackin'!
Sam Buchanan
RV-6
Fokker D.VII replica
Old 04-26-2014, 09:10 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
I would strongly suggest a SPOT tracker. Much more flexible use and portable.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 04-27-2014, 05:02 AM
NYTOM NYTOM is offline
Question Reporting site
Sam you convinced me a while back. Taking the exam in two weeks and planning on Allen's unit when I'm issued a call sign. Even installed a switch in the panel already. One area is a little foggy though. Exactly how do you get your plane on a web site. I find Vlad's "Where" N666BK" the best APRS reporting site I've found unless you have a better one. It's fast and extremely easy to get on and would be easy for my better half to locate me from her smart phone when she starts to worry. How does one register to a site like that?
Tom Norwood
Classic "Short Tail 6A N822PM
Old 04-27-2014, 06:46 AM
DanBaier's Avatar
DanBaier DanBaier is offline
One way is to go to "aprs.fi" (type this in the browser). On the upper right, you'll see call sign - type in whatever call sign you've programmed into the transmitter and that should do it.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 04-27-2014, 07:04 AM
I do as Don suggested. I give people the URL from aprs.fi
Once you done the "search" for the identifier, the URL for the browser will look like this ...
http://aprs.fi/#!call=a%2identif...3600&tail=3600
If you want to just type it in, the short form looks like this ...
http://aprs.fi/identifier
Here is an example ...
http://aprs.fi/N1IEK-8
Thes URLs are "live" so the are always show the most recent hour of beacons.
Old 04-27-2014, 07:36 AM
been here awhile
Tom, you don't have to register for www.aprs.fi, it tracks you whether you like it or not.
Here is the link to my track:
http://aprs.fi/#!call=a%2FN399SB&timerange=43200&tail=43200
Just substitute your call sign for the "N399SB" in the above link and anyone can follow you by loading that link. My link is set to show the last twelve hours of beacons. That is long enough to show the entire day of flying.
She will like this site!
Sam Buchanan
RV-6
Old 04-28-2014, 11:07 AM
Thumbs up Too Good to be True
Thanks Sam Glen and Dan. You know this whole system seems to good to be true ! I would think everyone would want one.
Tom Norwood
