Yes it was flying and I did not notice it until the inspection...
The bottom of the push pull tube has rubbed so bad it has chaffed the rivets of the control tube end and the carry through tube. It seems like the distance from the pivot point to the elevator push pull tube connection on the Fwd control stick is 1/4 of an inch to long or so...
thank you for your response. Mark
