I was curious if anyone has done a extended center console in the 8 to accommodate some additional avionics? I am between these to panels but real-estate as you can see is the issue:
Thanks in advance!
There should be plenty of room for a fully equipped panel in the -8, IF you leave the portable devices off and don't try to cram the largest size of everything in.
Here is a link to the panel in my -8:
http://www.vansairforce.com/community/showpost.php?p=796825&postcount=488
I have nearly 400 hours with this setup including lots of cross country and about 70 hours of IFR training under "the hood." I'm extremely happy with everything I have.
Here are some personal observations and opinions of your proposed layout:
1. With a good EFIS system, using the GTN-750 over the -650 is really pointless and a waste of valuable panel real estate.
2. Leave the iPad off the panel.
3. Since the -8 has a left hand throttle, moving the ignition key or switch to the right side will allow you to manipulate throttle and mixture with your left hand while cranking with your right hand. It's also a bad idea to have your hand away from the throttle when starting!
4. Toggle switches take up less room than a VPX console (or display). The vertical power stuff is really nice, but I consider these systems severe over-kill for our simple little planes.
5. The mounting structure for the panel means that you need to allow about 3/4" between your equipment and the panel edge.
Skylor
RV-8
