I just did this a few days ago and just followed the plans - no problem at all.
There is one important measurement on DWG 3, view B-B, distance of the doublers from the centerline (or where the HS-702 Fwd Spars meet) of 1 7/8". So the two doublers should give you a gap of 3 3/4", later the F-884 Attach Plate from the Vertical Stab will be nested inbetween (see DWG 78). This measurement should be close due to edge distance.
Also do not drill the holes which will attach the front spar to the fuse with screws later. These holes are only in the Splice and Reinf. Angles already (see View A-A.
I see your kit # is 83474 - mine is 83472.
