Old 04-28-2018, 10:07 AM
ERushing's Avatar
ERushing ERushing is offline
Default Higher Power Door Sheeting
Good Morning,
At Sun n Fun, I placed my order for a Higher Power Door to finish off our hangar. I'm researching options for sheeting the door. At this point I'm leaning towards steel PBR with horizontal seams. The hangar is pole barn construction with Hardieplank siding.
Any inputs on what you used to sheet your Higher Power Door? Pictures would be a bonus!
Thanks!
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
Old 04-28-2018, 10:32 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by ERushing View Post
Good Morning,
Thanks!
If insulation is not an issue, you could go with a smoked grey Lexan roofing material, just like the Horton Stackdoors.
Tough as **** and will let some light inside the hangar when the door is closed. Best if the door is not facing S or W though...
How it looks as a stackdoor -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-28-2018, 10:39 AM
Home Depot sells Sun Tuf brand. I put white on my single swing door about 25 years ago and it's still in great shape. My door faces ENE. It still provides good shade when open.
Charlie
Old 04-28-2018, 12:03 PM
loopfuzz's Avatar
loopfuzz loopfuzz is offline
I put in my order with them at sun n fun also. I'm guessing out doors will be shipped together. I was just going to go with the standard corrugated metal siding then foam insulation. And put in a few windows.
____________________
VAF donation made
RV-6A - Flying
RV-4 - Sold.
Old 04-28-2018, 01:33 PM
My HP door is 13' high, I bought 10' metal siding from Meeks and matching Pelram SunSky https://www.palramamericas.com/Produ...sheets/SUNSKY/ polycarbonate panels to fill out the top 3'.
Very happy with the HP door, and the way the skin finished out. The polycarbonate lets in plenty of light, but is high enough that folks cant look in.
Will try to get a photo up soon.
