Old 05-12-2018, 03:00 PM
JimWoo50 JimWoo50 is offline
Default Bradycardia?
My hangar neighbor says he has pulse rate of 45 while resting and was diagnosed with Bradycardia. He is about 60yrs and average ht and wt. I have never heard of this and always thought a low pulse rate was good. I told him I would ask on VAF for more info as to how it would affect his flying. So if anyone has experience or info Iím sure he would appreciate it.
Jim Woolard C56
N9855J RV-6 Donated 2017
Old 05-12-2018, 03:23 PM
YellowJacket RV9 YellowJacket RV9 is offline
Not a doctor, but a paramedic so I do look at lots of EKG's. In and of itself that heart rate is fine if it is a regular sinus rhythm, and if it increases with exertion, which is probably what the AME will look for. If it is irregular, or there are other issues such as an AV block or bundle branch block then there may be concerns but even then the FAA guidance is fairly relaxed as long as there is no structural heart damage found.
Here is some FAA guidance:
https://www.faa.gov/about/office_org...d/arrhythmias/
I had a recent patient who broke his hip in a bicycle accident. He was 70 years old and said he rode 50 miles a day. His heart rate was 45 and he said that was high for him, probably due to the pain.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 05-12-2018, 06:31 PM
If your heart rate is normally that low and you should ever need a pacemaker, be aware that it probably won't recognize that rate as normal and that could cause problems. It did for a friend of mine.
Old 05-12-2018, 07:50 PM
Paddy's Avatar
Paddy Paddy is offline
Default Low Resting Heart Rate
Endurance athletes regularly have resting heart rates in the 40's. I was a Cat-1 bike racer for many years and saw resting rate as low as 38 when I had good form. This did cause questions from doctors, but when I explained that I also had a VO2 max of 78 and a hematocrit in the high 40's (unassisted), they were generally satisfied
Flying as of 10/30/16 after 8 yrs building
Old 05-13-2018, 06:08 AM
bobnoffs bobnoffs is offline
chris is pretty much right on. bradycardia describes a heartrate less than 60. just like tachycardia describes a rate greater than 100. sinus bradycardia is good, it defines the rate as being generated by the normal neuro path. more investigation is needed. sinus bradycardia is one thing,bradycardia can be quite another.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12.
RV-12 kit as of 9/13
Old 05-13-2018, 07:45 AM
mturnerb mturnerb is offline
As others have said, bradycardia is of no concern if blood pressure and blood flow are normal - athletes have very efficient cardiovascular systems and do just fine with resting heart rates that are below "normal". Some medications (i.e. beta blockers for hypertension) lower resting heart rate as well.
In your friend's case, "bradycardia" is probably applied simply as a term that means heart rate is lower than the "normal" range (usually 60-100 BPM). It's a description rather than a diagnosis. Most physicians would ask the usual questions (exercise history, medications etc) and do nothing more (assuming EKG has been done) if there are no symptoms of concern. Typical symptoms I'd be asking about would be syncope (passing out), weakness/dizziness, postural symptoms - such as feeling dizzy or weak when suddenly standing up from sitting or lying position. If none of these are present and history makes sense (meds, exercise, or simply "it's always been low"), it's of little or no concern.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 05-13-2018, 11:57 AM
Default Thanks
For the info. I will pass it on.
Jim Woolard C56
Old 05-13-2018, 02:32 PM
kaweeka kaweeka is offline
As with what others said, it depends more on the reason for the rate rather than the rate itself. It may be physiologically normal with excellent conditioning or a sign of deeper pathology. In addition to an ECG, an echocardiogram would give information into hemodynamics.
RV-9A N435KR Vans calendar March 2018
IO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Old 05-13-2018, 09:16 PM
Jetj01 Jetj01 is offline
Default Bradycardia
As a guy with bradycardia, as one gets older, and we all do, bradycardia gets to be more problematic and the reason is with a slow heart rate IF there is a problem, your heart rates being low starts reducing the options if a ‘problem’ happens. So my heart went from being described as ‘athletes heart’ to ‘bradycardia’ and when it got ‘too low’ (41 bpm) I got a pacemaker, and not given a choice in the matter. Two months later and some change I got my Class 1 medical back and that was 10 years ago and several trips around the world. No biggy ��
Jj
Eagles Nest, TX
Built and FLYING RV-4 Fastback!
SOLD RV-6/RV-8/Rocket
Retired USAF, Current Boeing Driver
Dues paid ...thru 2017
Old 05-14-2018, 12:48 PM
pjoshyjosh pjoshyjosh is offline
Does anyone with Bradycardia have issues with drowsiness while at resting heart rate? I know someone who has had 2 car accidents but didn't realize he was falling asleep until after the accident - and then EKGs showed heart rate once in the low 40s and once right after the accident while strapped to a gurney still being around 70 (with all the excitement and shock should have been much higher)
So far he has not been diagnosed with any issue. EchoCardiogram complete, EEGs complete and no diagnosis (not even Bradycardia specifically).
Joshua Muri
N8306R - PA28-140 Purchased 05/2013
N72NJ - RV9A Purchased 10/2017
No N# - RV9/A Kit in progress
Empennage complete. Wing Kit on hand
