Old 08-19-2017, 07:35 PM
RandyAB RandyAB is offline
Default Nutplates...do you re-tap them?
I'm finding that the nutplates that I have been installing are incredibly tight when I try to insert the hardware meant for that nutplate. I actually snapped a screw on the access panels for the trim on the elevators. I ended up having to run a tap through each of them so I wouldn't have to torque so hard. Yesterday I inserted the bearings into the larger nutplates for for the elevator and rudder and boy were they tight as well. The hardware that I used is correct and I used Beolube.
I was wondering if builders regularly re-tap the nutplates before installing them?
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 08-19-2017, 07:40 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
No - using Boelube should be adequate.
Old 08-19-2017, 07:46 PM
sibriggs sibriggs is offline
Default tap
Yes, but don't run the tap all the way in, just a couple of turns so you only loosen it up just a bit, but it it will still hold torque, Some plates in non critical areas when the screws don't play a structural role, such as an interior panel may be tapped deeper.
Steve Briggs. RV9, G3x, G5, VPX, GTN625, PMags, A&P, IA, MCFII
Old 08-19-2017, 08:13 PM
BillL BillL is offline
Generally tapping at all is a bad idea, but I have gotten some off branded ones that had over crimped lower ends and were extremely tight. There are some nut plates that have a coating just for this reason.
I always use liquid boelube but have resorted to a tap for a few turns for some 4-40 screws. (shame on me)
Oh - always use steel screws to break in the new ones, not stainless screws.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 08-19-2017, 09:15 PM
vernon smith's Avatar
vernon smith vernon smith is offline
Using Torx screw rather then Phillips will solve the problem immediately. A little lube on the threads is good also. If you go with Torx be sure to buy good tools, Snap On or Mac are the best domestic but the Dewalt driver bits available at Home Depot are just as good and much cheaper. They are also good for Phillips bits.
Another big problem is not using the right size bit or screwdriver. You need the exact Torx bit ( 15,20, or 25) and either a #1,2 or 3 Phillips. The wrong bit (end) will strip out the head real fast, especially in the SS screws the aviation industry likes.
Old 08-19-2017, 09:20 PM
RV6_flyer's Avatar
If you do not have Boelube, Bee's Wax or even candle wax work well. I have a block of Bee's Wax purchased at a 'Gun Show' that is what I first reach for. May have something to do is that what we used at work over 30-years ago.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-19-2017, 09:31 PM
The head didn't strip, the bolt sheared right off!
In Canada we have Robertson square heads that are much better than Phillips heads. I don't know if they are used south of the border at all.
Randy P.
1st time builder
2017 dues paid
Old 08-19-2017, 09:32 PM
With great difficulty it seems.
Randy P.
1st time builder
2017 dues paid
Good to know!
Randy P.
1st time builder
2017 dues paid
Old 08-19-2017, 09:35 PM
wirejock's Avatar
wirejock wirejock is offline
Default Tap
I do it this way too. Boelube on the tap.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
