Hey Gang,
I?m using 3 MGL ECB?s (electronic circuit breaker) plus 2 of the MGL switch kits on my RV project. Anyone else use these?
Here?s the problem. They sell you a little circuit board, switch, 3 lead LED, and the LED housing. When putting the LED housing over the LED, the outside LED leads short out on the LED housing and the LED housing is mounted on the Instrument panel which is connected to aircraft ground? I tried to put heat shrink tubing over the LED leads but now it?s too fat and the housing won?t go over the leads? I?m obviously missing something fundamental here?
Anyone else use this MGL switch kit and how did you deal with this issue?
